2018 S5 SB Brake Caliper Bolt
#11
I'm not sure why anyone would want to mess around with those two bolts. From the service manual, it states that to never loosen those two bolts. There's a reason they are special bolts. You don't need to remove them to change your pads.
The following 2 users liked this post by luder888:
Nikon1 (06-24-2019),
SolventSolution (06-24-2019)
#12
luder, could you point me in the direction of the service manual? Is this available for download? Thank you!
#13
Thanks for the clarification and the quick response. I managed to find the instructions on how to remove the calipers.
[img]file:///C:/Users/SAJEEL~1.002/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/img]
[img]file:///C:/Users/SAJEEL~1.002/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg[/img]
[img]file:///C:/Users/SAJEEL~1.002/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg[/img]
[img]file:///C:/Users/SAJEEL~1.002/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg[/img]
#15
#16
Hi all, typical I find this thread "after" I chewed up the 2x bolts that are never to be loosened... does anyone know the reason why they are never to be loosened (torque setting or other). I want to put it right. Thank you.
#17
I am sure there will be a relevant section (not maintenance, repair / rebuild) within B9 S4/5 erWin resources. So perhaps a 24 hour subscription to download whatever you need. Two new bolts, the correct socket tool, and some red Loctite should do the job and not be expensive. This happens quite often, I've read about it in BMW forums. It is natural to see a bolt, and want to undo it 😂
pearlwhitesix
12
03-29-2012 09:31 PM
deephouse
Audi Original "S" Cars
12-03-2008 09:13 AM
maaliish
Canadian Discussion
08-05-2008 07:32 AM
maaliish
A4 (B7 Platform) Discussion
08-04-2008 06:36 AM
Der Wolf::Indukted
06-29-2007 10:22 PM
