A5 2017 transmission
Audi A5 2017 gearbox in limp mode after I change oil put it in any Gear still won't move after I drain the oil out of my Audi I put back 4 litre inside the box I could not put any more start running out I was told 7 litre should be in the box I tried to put it in gear it did not move i put it in D and reverse and it still won't move is anyway around this time I doing something wrong
Submitted by raymondrichard… on 16:45 pm Sat 11/03/18.
Club AutoUnion
I drained the transmission that's what I drained I refill it with 4 litres of oil transmission I was told a 7 L meant to go back in the box
but I managed to put only 4 no more once I open the gearbox more is running out so put the plug back in what can I do to put the rest of oil in the gearbox
also when I put it in drive reverse or any Gear it doesn't move display come up on dashboard gearbox
you you need to read up on this. It’s not as simple as just dumping the fluid and refilling. You have to fill up, heat up the fluid, cycle gears, add more fluid etc. There is a process
i would start with YouTube or some other forum. There is a drain plug on the outside and I don’t know about the 7 spd but on the old 6 spd dsg there is an internal plug as well. Maybe why u can only get 4 litres in. You also are supposed to use VCDS or some ther tool to monitor the temperature. DSG fluid expands as it heats up and to get the levels correct you shouldn’t just be guessing at this. Sounds like this might have been a service better left to your dealer
