A5 coupe rear trunk lip
#11
The side that is overlapping a bit is the long side, wich is calculated by them using the angle you provide, so if you ask for an angle like 119 or 118, the long side length should be smaller than 1300 mm.
If you have any other question let me know.
Upload some pcictures when you get it!
#13
Which spoiler option are you calling stream lined?
Did you guys notice the original posters link to the spoiler has no length data field to enter. Have the settled on the correct size thus you no longer need to provide that information?
Thanks
Thanks
#14
The SB version doesn’t fit on coupes.
#15
I'm sorry, but I don't understand. If the SB does not fit on the coupes, what exactly did you order to put on your coupe? Pardon me if I'm being a moron, but I can't figure out what to order for my coupe when I search the ebay postings.
#16
So I will suggest you to write to the seller and ask for a customized trunk lip with the measurements provided.
Hope that answers your question
Regards!
#18
Turns out they can't do 118 or 119 degrees. They apparently can only change in 5 degree increments so the choice was either 120 degrees like the OP or 115 degrees. I went with 120 degrees because the OP's pictures looked quite nice despite the tiny overlap.
#19
So forgive me but what angle on the spoiler are we calling 120 degrees? The end cut the overall curvature?
Couldn't you just shorten the short side measurement by 4 mm to also shorten the too long overlapping long side?
Thus not requiring a need to change this angle measurement?
#20
The 120° angle is measured as follows:
