Adding oil dipstick on B9 S5 at all common?
I was reading through the thread on excess oil in engine and saw several references to possibility of adding a dipstick. ECS lists a fancy one and says just remove a dummy plug and drop it in. parts.audi lists a full dipstick tube assembly, but no comments on that being a replacement piece or something to be added if you want to install a dipstick. A dipstick tube would make interim oil changes with suction really easy as well.
If this was so easy, I would have thought it would be a popular add for anyone tinkering with their car, but I haven't seen anything along that line so far. Anybody have insight on this?
Club AutoUnion
Buy the ECS! It’s literally as simple as removing the factory “plug” and installing the ECS dipstick. It’s not fancy — it just works.
— John
— John
DaveSNJ (04-16-2021)
^^ what John said ^^
I guess this is my win for the day. Right now, all three of my cars are missing dipsticks and I still hate it. So much info as to oil condition as well as levels, etc with stick. The Porsche flat six has no option, due to the circuitous line from engine to anywhere you can reach without disassembling panels. That is a Boxster, so you can't even see the engine without some disassembly.
Delayed gratification here: Back ordered at ECS until October but placed order anyway. Looks like I was the only one in the dark on this.
I have the ECS stick, but I don't leave it in the car. I only use it to check oil level and color. My fear is that it may fall apart (multi parts stick) and blow up my engine (I know I am paranoid.).
I now use the factory stick (part number T40178), only during oil fills and checking color since you cannot leave this stick in the tube anyway. I use this stick to also fill my Touareg TDI's oil too.
P.S. These new cars with sensor for oil level are really touchy as far as oil level overfill is concerned. So, the factory stick with graduated reading is very helpful.
dadrocker (04-20-2021)
I actually just got it yesterday and threw it in after changing my oil for this first time this past weekend. It's in the ballpark oil level of what the MMI readout is. I'm happy to have an orthogonal method to verify the MMI reading.
If it did fall apart, it would never make it past the oil filter to the engine - if it was even able to get picked up out of the pan. So i think you're still safe to leave it in if you wanted, but also nothing wrong with leaving it out and using the plug - whatever floats your boat!
Note: ECS is having customer service problems recently: https://www.audizine.com/forum/showt...stomer-service
The ECS dipstick is the most robust dipper I've ever seen/used.
Nikon1 (04-16-2021)
Club AutoUnion
As @synergize said, I cannot see how this would “fall apart” as the picture below shows how it is made:
As to their Customer Service, I would think this pandemic is having an effect on most small businesses.
As @synergize said — When you take the car in for service, either pull the dipstick and re-insert the factory plug in the tube (though it’s a pita to get out again) or make sure the Service Advisor notes on the work order that the engine has a dipstick installed and check that the dipstick was replaced after they drained & refilled the crankcase. I’ll be taking mine in for its 3 year service in a couple of months and my Service Advisor knows to state on the work order that there is a dipstick installed.
— John
— John
Since the "wire" is pinched with the handle on one end, and a piece of metal on the other end, they can possibly separate. The joints are not "welded." But of course, this is just me being paranoid. The stick is well made, I agree.
