Auto Hold Button Installation
#21
Yes. I had it on the BMWs too and I would love to see it on the S5. Like others, I also use the ACC for this purpose or the parking brake (once the car behind me has stopped) as a workaround. A little more involved but OK for now.
#22
YES, This is exactly what I was hoping for, a video that shows it. I've already gotten the first piece off.
And for those of you wondering, "Is auto hold worth it?" I suggest going down to your local KIA dealer and test driving the GT2 Stinger. That vehicle comes with auto hold and is a good example of what it can do for you. I never would have thought twice about auto hold but when I test drove a Stinger on a whim I decided I liked it. After I get it installed on my 2018 S5 Cab and use it for a while I may do our S5 SB and Q7 as well.
So so what’s the logistics? Do you press the button each time you stop? Then the brake is auto applied? Does it change the stop/start function? I’m away from home so I have no easy access to owner’s manuals - US or otherwise.
i have VCDS, obdeleven, and Vag Can Pro so with the proper instructions I’m sure I could do the adaption.
#23
Need Some More Help
I got the center console apart and have installed the auto hold button. However, the next step is to add two wires to the J519 module. BUT I CAN'T FIND IT. Does anyone know where it is located in the 2018 S5 Cabriolet? In the older S5 it was on driver's side under the lower instrument cover.
Please send pictures/videos/or anything that will help.
Thanks
Byron
Thanks
Byron
#24
Thanks
Byron
Thanks
Byron
#25
It pretty much is, IF you can figure out where to plug it in. So far 4rings.us has been UNABLE or unwilling to provide the information necessary to complete the job. They sent me information for a 2007 S5 Coupe which is far different than the 2018 S5 Cab I told them I was buying it for. I have been waiting since mid-June for the correct information. I have emailed them several times and they are not answering. Is it possible they are no longer in business or are they on summer vacation and don't care what happens to their business?
#26
I’m intrigued with this. My S5 is my first ever auto and I probably would like the hold function. And I even have DAP too.
#28
https://www.audiworld.com/forums/q7-...rofit-2956539/
BUT I found this thread about someone trying to install Auto Hold in a B9 A4 which says the module is located in the passenger side glove-box area:
https://www.audi-sport.net/xf/thread...ectors.390286/
Here is another post from someone that installed a different kit in a B9 A5 which also says it's in the passenger side area also:
https://www.audi-sport.net/xf/thread...2#post-3224232
Hope this all help.. Interested in doing this myself so please document with photos as you figure it out. Thanks!
#30
Thanks Again heymoe
Here is a thread about installing this kit in a Q7 which says the J519 is located at the left side panel of the driver side foot-well (includes wiring diagram).
The car is now back together, but I have not been able to finish the coding. There are three steps to the coding and I quote:
Stg 09 - Byte 15 - Bit 6 [0>1]
Stg 03 - Byte 18 - Bit 6 [0>1]
Stg 03 - Byte 30 - Bit 1 [0>1].
I was able to do Stg 09 as the Bits showed up and I clicked on Bit 6. But in Stg 03 when I go to Byte 18 and Byte 30, the Bits don't show up all I get is:
Byte 18 Binary 10011010
Byte 30 Binary 01011001.
And I don't know how to interpret/change them properly. Any ideas??
Stg 03 Byte 18
Stg 03 Byte 30
