Auto Hold Button Installation
#61
10. Coding consisted of accessing two controllers: 09 –Central Electronics and 03 ABS Brakes.
11. 09 –Central Electronics was easy as VCDS broke out the Bits on Byte 15. So I simply clicked on Bit 6.
12. 03- ABS brakes was a bit more challenging as the Bit breakout wasn’t there and I had to figure out the Binary code. But it turned out fairly simple:
13. Go to Byte 18 and in the Binary change 10011010 to 11011010:
14. Go to Byte 30 and in the Binary change 01011001 to 01011011:
My Car... Control Units... 03 Brakes... Long Coding... Scroll to Byte 18... to change the binary from 10011010 to 11011010 click Bit 6 on
My Car... Control Units... 03 Brakes... Long Coding... Scroll to Byte 30... to change the binary from 01011001 to 01011011 click Bit 1 on
My Car... Control Units... 09 Central Electrics... Long Coding... Here's where it changes...
There's no Byte breakout, just a bunch of sub-controls. One of them reads, "autohold_switch not_installed". I have no idea if that corresponds to Byte 15 in VCDS, but it should, right?
#62
Glad to help.
#64
As others have posted — if I use the e-brake button, I wait until there is a vehicle stopped behind me. That’s no guarantee that the person behind me is paying attention to my brake lights and won’t assume that when I apply the e-brake and the stop lights go out, that my vehicle is actually moving!
That’s how I got rear-ended in my last car — young female driver was too busy texting, saw the traffic light turned green and forgot there were 5 cars between the intersection and her car, so even though my brake lights were still on, . . . Driving & Texting!
— John
— John
#65
Club AutoUnion
#66
#67
Club AutoUnion
I emailed them regarding programming using OBDEleven and received a reply within 24 hours. They say they are not familiar with it, but shouldn't be a problem assuming it has the same abilities as VCDS. I decided to take the dive and ordered it from them because of their wiring harness.
— John
#68
Can the dongle from Kufatec be used more than once? Just wondering if I order from 4rings, maybe I can buy the dongle from someone who installed it from Kufatec and doesn't need it anymore.
#69
https://www.kufatec.com/en/coding-di...fy-q7-4m-42076
My understanding is the dongle can be used multiple times. They even using the example of getting a firmware update that might reset the values and disable the Auto Hold coding as a reason to use the dongle again.
#70
David
