Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
Automatic Opening of Car When Approaching
Old 05-18-2019, 10:01 AM
johncaravello's Avatar
Default Automatic Opening of Car When Approaching
Has anyone been successful in getting this to work using OBDEleven and long coding? If so, I can really use some guidance please. Feature sounds intriguing.
Old 05-18-2019, 10:44 AM
Ajax1900's Avatar
Do you mean the ‘welcome home’ feature on the OBD apps list? I don’t think it unlocks the car, rather it just turns on all the lights when it senses you are near. Which is very cool.
Old 05-18-2019, 05:15 PM
I actually am talking about automatic opening but what I was trying to achieve having the car light up as I approach it so welcome home might be what I really want. I will look into that app. Thanks
Old 05-18-2019, 05:33 PM
No that's not it. What I was hoping to do was have the A5 turn on its interior and door handle lights as I walk up to it without having to touch or use the key fob in any way just have it in my possession.
Old 05-19-2019, 10:37 AM
RichardG's Avatar
Found this located in this thread post #17 https://www.audizine.com/forum/showt...DS-mods-for-B9 I have not tried it so not sure if and how it works. This is for VCDS, not sure if OBDeleven long coding works like VCDS?
Or try this link https://docs.google.com/document/d/1...h.vxkqcd7up3hh
Activation of automatic opening of the car when approaching
The cart opens automatically when you are about 1-2m away.
[46 - Central Convenience] [Coding - 07]
automatic_opening
set to active
Old 05-19-2019, 04:34 PM
Thank you RichardG. I will look these docs over.
Old 05-20-2019, 06:56 AM
Thes6isWicked's Avatar
I have successfully activated auto unlocking, however, after locking the car, if you don't walk away fast enough, it unlocks again....
Anybody have an idea how to stop this?????
Old 05-20-2019, 08:04 AM
heymoe's Avatar
Wonder if there is an automatic_closing/locking option that can be activated also using the OBD11 so that it locks the car after you move 1-2m from it.
Old 05-20-2019, 08:36 AM
Eli McCraig's Avatar
I activated Auto Unlock as I approach with Carista-(beta tester for B9). Now courtesy lights come on, and all doors unlock as I approach. If i walk away, it will auto lock too. I could have set to all doors unlock or just drivers door.
Old 05-20-2019, 09:08 AM
When I went into the long coding of Control Unit 46, I noticed something labeled automatic_closing right below automatic_opening. Both were set to not active. I didn't want to be the guinea pig so I stayed away. I'm sure someone out there has a bigger set than me and will try it out!
Step right up!
Quick Reply: Automatic Opening of Car When Approaching
