Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
2019 Audi S5 B9 Speaker replacement
Old 09-25-2020, 07:12 AM
Sam Khazali's Avatar
Default 2019 Audi S5 B9 Speaker replacement
Hello everyone
I did a speakers replacement on my Audi s5 recently. total job time took about two weeks. the results are amazing. you can check google drive link for the photos.
products I used in this setup
  • Focal performance PS 165f3 for the front door.
  • Focal ps 165fx for rear door.
  • JL audio FIX-LSA-4
  • PAC LP7-4 hi low converter
  • JL audio TWK 88
  • JL audio RD400/4
  • JL audio acp110lg-tw1
  • RCA cable
  • MPOW ground loop filter
Google drive photos link
https://drive.google.com/drive/folde...eN?usp=sharing
If you have any question about this setup, please let me know since I used plenty of time to understand and fix all the problems I faced. I'm also a certified MECP professional automobile installer
cheers
Nikon1 (09-25-2020)
Old 09-25-2020, 07:45 AM
bruce_miranda's Avatar
Nice. Any particular reason you didn't just use a NavTV ZenV? Where are all the tweeters located.
Old 09-25-2020, 08:24 AM
I was afraid that i end up with code. the car under audi werranty and i don't want to fight with them. But, still thinking about and i don't have to do much change. Just remove my hi low and add this.
Old 09-25-2020, 11:33 AM
I'm guessing you would have found this handy? Car's harness plugs in on one end and a row of terminal blocks gives you access to the wires without having to cut anything. Great for retaining warranty.
That connector with wires, is in case you wanted to go back to the B&O on the other end.
Old 09-25-2020, 11:44 AM
great advice. Also, all the wire i did are bullet connector male to female so they are removable and numbered to make sure i can put it back anytime
Old 09-25-2020, 11:51 AM
Are the all the speakers that you aren't amplifying still being driven by the B&O amp? The 2 x centre channels, 2 x rear surround, 2 x 3D mids, 2 x 3D tweeters.
Old 09-25-2020, 12:16 PM
yes except the two top 3d tweeters. I had to desable them to use it own wire for my tweeters since the factory tweeters and 4 inch mid speakers are using the same wire
Old 09-25-2020, 12:20 PM
Ah, so you are using the same trick I mentioned in the forums. Nice.
Is the B&O centre channels blending in well with your other speakers?
Old 09-25-2020, 01:07 PM
Yes. I actually thought about my self lol. Can i see your forums so i see what you did or mentioned? Like you send me the link to it please
Old 09-25-2020, 01:14 PM
I haven't done anything like what you have managed, I am no professional.
Any photos of the rear doors or how you installed the tweeters in the A pillars or rear doors?
Sam Khazali
Audi A5 / S5 / RS 5 Coupe & Cabrio
09-25-2020 07:10 AM
Motowey
06-30-2020 05:14 AM
Motowey
01-31-2020 01:58 AM
Motowey
Audi R8
01-30-2020 05:25 AM
A5_4GP
09-11-2009 09:49 AM
Quick Reply: 2019 Audi S5 B9 Speaker replacement
