B&O owners - what are your settings?
Just interested in your
Sub Base Treble Fader settings measured in notches negative or positive over midway. I know source is also important, but that is not part of this ask. With the brief plays I have had with the things I chose Sub +1 Base +2 Treble +3 Fader 0 |
Sub +3
Base +2 Treble +1 Fader 0 |
Sub +3
Bass -1 Treble -2 Fader 0 |
Thanks! My ears are shot on the highs I have to tweak up a little.
Sub +9
Bass +9 Treble -3 Fader...how are you quantifying the fader? Mines at: https://cimg2.ibsrv.net/gimg/www.aud...84c53c236.jpeg |
Originally Posted by SolventSolution
(Post 25341430)
On SD card with lossless FLAC, I'm at:
Sub +4 Base +4 Treble -1 Balance,Fader 0,-3 On FM HD: Sub 0 Base +2 Treble +4 Balance,Fader 0,-3 On XM: Sub +2 Base +1 Treble 0 Balance,Fader 0,-3 |
Originally Posted by MH62
(Post 25341433)
I didn't know until I saw this post earlier today and like you I have been using the trackpad crosshair to adjust balance and fade but you can actually use the MMI scroll and click to adjust them.
thanks 👍🏽 |
(Post 25341437)
Sub +4 Base +4 Treble -1 Balance,Fader 0,-3 On FM HD: Sub 0 Base +2 Treble +4 Balance,Fader 0,-3 On XM: Sub +2 Base +1 Treble 0 Balance,Fader 0,-3 Thanks! |
Originally Posted by audijk
(Post 25341594)
Are you changing this manu,you each time you switch inputs or can you set each input up individually?
Thanks! You can set each source individually for the sound shaping in the MMI but, unfortunately, not the individual source input levels. Switching from the audio on an SD card to the XM /Sirius source is quite shocking unless you remember to decrease the volume prior to switching those sources! I was afraid I might have damaged a driver the first time I did that. — John |
