B9 S5 Strut Brace
#81
I got to drive my car today, felt a lot more precise on the steering despite the winter tires. In big sweeper turns you can really feel it. Very happy.
Install note, this was one of the easiest mods I have ever installed on a car. I can see how some might have trouble if they are inexperienced at wrenching. One thing to note is that when getting the allen key into the underside bolts, you need to use the long end first and use one finger on your non wrench hand to guide the wrench into the bolt. Once you tighten with the long end its easy to go back with the short end and tighten the 4 bolts even more. Access to the bolts is not impeded at all so if you are having trouble getting the tool in there you're doing something wrong technique wise.
I was able to tighten both sides to a fixed position very quickly, I then just lifted the front of the brace up to access the bolts (~30 degree angle) with my torque wrench, finally applying the brace point bolts.
#82
Just installed mine yesterday, I was able to torque the hex headed bolts underneath using my short torque wrench and a universal joint. There was only a very small loss of blood involved.
Only driven it to work this morning but, I *think* it is a positive improvement, especially in turns where you switch from right to left like around a roundabout and then taking the exit (and I have the cabriolet, which seemed to handle much better than my old B8 Coupe anyway). All just seems a little bit more precise and controlled. I'm also happy to kid myself that this is the case :-)
#84
I also just installed my strut brace. It's really not that hard. I used the previously suggested method..... Loosely install into the vehicle all three parts as one unit. Snug down the passenger side underside allen bolts with an allen key. Take all out as a unit and torque the passenger side. Reinstall and torque the four factory mounts. Then use the torque wrench with a universal to tighten the driver's side two allen bolts. It's tight in there, but not that bad.
Installed during a 14" snow + 50mph wind blizzard. No chance to test yet - most roads are still closed.
#85
As an interesting aside, I have right now a loan A5 from the dealer and the factory strut brace is different to the one that was on my S5.
A5 - Silver, two bars, not apparently joined together.
S5 - Black, one piece, joined together with a cross piece near the apex.
So the S5 already had an up-rated strut brace, which I was unaware of. I wonder if the RS5 had an even better one from the factory or the same as the S5?
#86
#87
The part number was 8W7 805 629 A.
An unexpected issue today, got a letter from FedEx about the import taxes and their fee for collecting them, another £37 on the price :-(
#90
Interesting. If and when the sale ends on the ECS site this looks like another alternative. Not as beefy or pretty as the aftermarket solutions but a welded cross bracket should add some strength when compared to the two silver bars that came stock on my S5 Sportback. OEM center reinforced strut brace . Thanks Paradyne.
