Best bets for winter tires for New England?
2018 S5 Cabrio with the 19” wheels, if that matters. This will be my first winter with it so need to get some appropriate skins and wheels. I live in the city and don’t daily drive, so I’d be a little biased towards a tire that has somewhat more dry performance versus maximum snow/ice capability.
Also, kind of a goofy question, but can I fit four mounted tires in the car? Just planning ahead for driving somewhere to pick them up and needing to bring my summer wheels/tires back for storage.
Club AutoUnion
Prevailing logic is since you’re buying wheels & tires, step down to an 18” wheel and tire. This should give you a taller sidewall and (hopefully) prevent wheel damage when the potholes appear in the later winter & spring.
There are several Winter Tire Threads in the forum for the B9 cars if you search back a page or two.
Found the thread — Winter Wheels & Tires
If you mostly going to be driving on cold and/or wet roads with just the occasional drive in semi-plowed snowy roads, then I would recommend taking a look at the Michelin Alpin PA4. The tire is extremely quiet and comfortable with excellent grip in the cold that doesn't turn into greasy mush during the occasional warm days that you will frequently get at the end of winter and beginning of spring. It also is competent enough to get through real snow when you need to.
However, if you need to make regular trips out during snow storms or right afterwards before the roads are properly plowed, then consider something along the lines of a Hakka, Blizzak or X-Ice, all of which will give you a better bite in snow but at the expense of a noisier tread pattern and less traction whenever the temps start to climb into the 50's.
I concur on the 18" wheels for the winter too. Less protection from potholes, and cheaper for both wheel and tire when even that protection is not enough.
Club AutoUnion
I think he meant more protection from potholes and, if size your tires on the 18” wheels correctly, you’ll get better traction on a slightly narrower tire.
I went with an 18” setup from Tire Rack with the Michelin X-Ice studdless snow tires. They have excellent dry, wet and snow traction yet still handle ok in back twisting back country roads. Here’s the link https://www.tirerack.com/cart/HoldingArea.jsp
Tire Rack shipped them mounted and balanced with the centering rings installed and the 20 lug bolts that match the rims. The final product looks like this
demarad1 (08-29-2019)
Too sweet looking rims for winter!! LOL!
agreed...
This is why I went for the Alpin PS4's this time around. I realized that I actually spent very little time driving on snow due to how quickly the roads get cleared in NJ. On the other hand, I found that I was spending a LOT of time driving around on warm dry roads in the Spring when the temperatures would climb into the 60's for days at a time followed by a quick snow storm that negated the ability to switch back to the summer tires any time before late March. The Alpin's have no squirm at all, not even when it gets warm.
Sounds like the Pilot Alpin PA4 would be a good fit for me. Does this combo look right? 18x8 wheel and 245/40R18 tire. Selected the Enkei wheel because it's one of the lightest, not sure if there is a stronger choice as I know a lot of these cheaper cast wheels aren't the most robust. I don't have a problem spending a little more for quality.
