Brake pad change question
I am getting ready to change the front pads on my 2018 S5 Convertible and was wondering about whether or not anyone opens the bleeder screw while retracting the pistons. I’ve never done that on any car in 40 years of doing brakes. I didn’t do it when I changed the rears a few months ago. I was watching a couple YouTube videos to make sure I had the proper sockets (had to buy an M10 triple square socket) and I saw two people said to open the bleeder because you could damage the one way ABS pump.
So my question is, how many of you do it and how many don’t? I’m hoping I don’t risk having to bleed the system after that. |
I do not open the bleeder screw, after changing brakes on 4 Audi's no issues at all.
The workshop manual by Audi says nothing about messing with the bleeder screw when resetting the pistons. Never done it, never had a problem. It does say make sure the fluid level in the reservoir is not already at the max line. If so, there's no place for the fluid to back up into as the piston is pushed back; you have to extract some fluid from the reservoir first to make room.
Originally Posted by SMac770
(Post 25874211)
I’ve never done it either and this is the first time I’ve ever heard anyone suggest doing it. I always check the reservoir to make sure it won’t overflow. |
This guy works at an Audi dealer. He doesn't loosen the bleeder. He has many videos on many items including brakes.
as stated, make sure you are not near the top of the reservoir or when you push the pistons back in you will volcano brake fluid in the engine bay which is a total mess. ask me how I know. HAHA.
Originally Posted by mhoran89
(Post 25875506)
AS a customer, not a mechanic, what's the benefit of not trimming the rotors? Or rather what's the downside for going to a small repair shop and asking for a rotor trim?
Originally Posted by jwizzle
(Post 25875768)
(Post 25875768)
I was quoted something over $1,000 for replacing my rear pads, rotors & whatever else is required. If I went to an indie shop and specc’d the same type of non-OEM parts, but not higher-end parts, I would guess I would trim between $250 & $300 off the dealers price. And, again, this is my opinion (based on doing some research) and it may not be exact based on your area & labor rates. — John |
