Can an OBD modify ...WiFi off time?
As the title implies, I’m trying to extend WiFi activity in car when it is in parking mode.
I’ve got the plan with ATT, obviously it goes off when the power does.
Does anyone know whether there is a setting that can be changed?
Thanks,
Thanks,
Not sure what you mean by "power off", if you mean after you turn the engine off then the answer is that is control by the car computer and you can not change it. The design is such that you can't run the battery down so that car won't start. Of course the solution is to leave the engine running and use fuel and if in an enclosed space take a chance of killing yourself with carbon monoxide,,,,
Seriously, the WiFi utilizes the MMI infrastructure which pulls battery power and you don't want to end up with a dead battery. I do know when a lot of phones are "tethered" to a laptop for example the phone monitors the "activity" on the connection and if it doesn't see any activity for a certain period it will turn the tethering off. It doesn't sound like this is your issue with AT&T because if you're using it they shouldn't cut it off.
Thanks your reply.
bigdawg56
11-16-2012 04:31 AM
TwisTTer
27
05-05-2008 08:11 PM
The Crapple
Audi Original "S" Cars
16
09-17-2006 10:24 AM
