Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
Heat / AC acting on its own ??? Anyone ?
Old 01-19-2018, 09:21 AM
coupegt87's Avatar
Default Heat / AC acting on its own ??? Anyone ?
So I'm driving the other day on my way home and I have the heat on at 72 degrees, about 10 min into the drive I notice that the A/C is ON.... I started the my drive with the A/C Off , does anyone experienced similar situation ?? It happened to me Twice in 2 days .....
Old 01-19-2018, 09:51 AM
Eli McCraig's Avatar
If it is in auto, this is normal.
Old 01-19-2018, 11:45 AM
N8!
N8!'s Avatar
Auto mode means the AC is always on.
Old 01-19-2018, 11:50 AM
bluaudi's Avatar
Even in the winter
Old 01-19-2018, 02:24 PM
coupegt87's Avatar
Really ? .... even if the outside Temp. is 25 degrees ?? doesn't make sense
Old 01-19-2018, 02:40 PM
stan23's Avatar
Yes, because AC + heat is the quickest way to keep an interior defrosted. Auto mode will almost always turn on AC.
Old 01-19-2018, 05:15 PM
Wiz33's Avatar
Yep, AC helps remove the moisture from the air.
Old 01-20-2018, 09:35 PM
lowjdml's Avatar
When I don't need defrost, I hit the AUTO button and turn the AC off. The auto light stays lit and the AC stays off even when I change temperature.
I only turn the AC on when I want cooling.
jjobev
Q7 MKII Discussion
21
05-31-2018 05:55 AM
rentonrenton
Q5/SQ5 MKII Discussion
10-26-2017 07:05 PM
Kaitlyn2004
Q5/SQ5 MKI (8R) Discussion
9
11-29-2013 12:51 PM
ImolaAvant_GA
05-06-2002 04:10 PM
jmr
11-10-1998 04:35 PM
Quick Reply: Heat / AC acting on its own ??? Anyone ?
