Does 2019 S5/RS5 have turbo lag?
#11
If you were not in dynamic when you started the car then once you change it to dynamic mode then you will automatically be in sport.
However, if you started the car already in dynamic then you were not in sport mode (unless you physically moved the shifter down once afterwards)
#12
Thx for posting your experience. Since you have test driven both, you can relate the two more closely. The lag that bothered me was when I was driving say 20-30 mph speed and then I put the foot down and I expected it to respond right away but it took some time before it took off. Again, not 100% sure that I was in Sport mode but when you test drove it, you didn't find lag in S mode from Stop position or even when you were just driving in slow speed and you wanted it to just take off?
#13
I test drove the C43 AMG before buying the S5 and the C43 AMG is definitely quicker off the line. I did not notice any lag in the S5 when in sport mode, In normal mode, there are some lag, BTW, it more likely that it is transmission lag, not turbo lag. I see the C43 AMG as the bruiser of the two. The C43 AMG is normal mode is almost the equivalent of the S5 in sport mode. The sport mode in the C43 AMG is insane, more suited for the track. Interior wise, no contest for me, the Audi interior is second to none. I needed a day to day driver and a weekend car, that is one of the reason I bought the S5 over the C43 AMG. The Audi just felt more refined to me. You should go test drive a S5/SR5 again in sport mode.
P.S. It also kinda emphasizes the mission of a car if it has two sport modes and only one normal mode, and the AMG S models have a third sport mode "Race" specifically for the track. Audis have two normal modes and only one sport mode, except for the R8 V10 Plus with the Performance mode that sits above Dynamic.
#15
Yes, my current car is a 2018 S5. I see in other replies here that you were asking about rolling response, and that really has no problems with lag at all. In Sport mode, the car holds in lower gear a bit longer, so the RPMs are already higher when you floor the pedal.
I'm really thinking that you need to go back and do another test drive, making CERTAIN that your gauge display indicates Sport.
#16
FWIW... with my '15 S5... (3.0T Supercharged v6) in Dynamic mode (only), there is a slight hesitation if I try to jump on it... but once the beast winds up it's fine. Now.. a simple pull-back on the shifter to engage Sport mode (plus Dynamic) and the throttle response is darn near instantaneous. And the shift-points are "sportier" (higher RPM)... which is so much fun, that I often compare the straight line acceleration to my Corvette (400 hp LS2) in that it feels about the same -- w/o all the NVH! Very fun!!
#17
In the $61k C43 sedan scenerio, selling car for $54290 (11%), 48 months, 10k miles a year = 53% residual.. $1200 down plus 1st month = $625
So what can I expect to get an S5 for? Can I expect similar (11%) off on MSRP?
#18
Good hunting!!
#19
I had to search quite a while to find my '15 S5. I was looking for less than 25K miles... with the v6 and SC (i.e., no turbo) and with all the bells & whistles (B&O stereo, MMI Nav, etc.). Finally found a 1-owner with 24 K miles on the clock... with about 50% of it's warranty and two services left on an AudiCare maintenance package. It was a trade-in at a Merc dealership that didn't want it on their lot. I ended up getting it for about $5,500 under Fair Market Value.
Good hunting!!
Good hunting!!
#20
There is a thread on the S5 and SR5 pricing in here somewhere. The S5 will have much more discount than the RS5, its supply and demand. The last time I check, depending on where you are, the S5 can average $8K to $10K off while the SR5 will be much less, $2000 to $3000 off.
