DT Power - New Products
#11
Very interested. With the power control tuner how does this play at higher speeds? I feel like the power band is not as noticeable at higher speeds (70mph full throttle)? I dont have any issue with the torque curve and acceleration at lower speeds, but it seems to fade at higher speeds in stock form. Really just looking for “seat of your pants” differences.
#12
#13
I have the TCU tune with the box and all I can say is that the gear changes are much smoother. I run a file from Aaron with more boost and that tends to give erratic/choppy gear changes at partial throttle so I could only use that file at the track on full throttle. Now with the tcu tune it is a lot smoother so I can now drive that file on the street. This weekend I will do some testing at the track and we will see if I can beat my best time of 11.89@115 that was done without the tcu tune. I know the product is not advertise as something that will make the car faster but if it does, it will be double bonus. Great product!
#14
Aaron, so the tune simply plugs into the OBD port and you shoot the tune from your cell phone to the unit? There is
no piggy back Hardware or anything ? Also, the website says that the S4/5 models will have numbers of ...
- Dyno proven 410 crank HP / 462 Crank Torque
#17
The power gains are dyno proven and correct. I have personally had the car on the dyno and you can see the review I wrote before I went in to business selling these. I believe the links are in the main post but you can also find them here. https://www.audiworld.com/forums/s4-...eview-2928574/
The TCU+ Transmission tuner does plug into the OBDII port and the tune process is is pretty simple. This changes the power delivery and shift settings to make a decent setup even better. The two work well hand in hand.
