Early observations/reviw
Got a new '18 A5 cab for my wife (2nd one). She loves it, and it's fun to drive. New engine and 7 speed dual clutch auto are a nice combo. Aside from some strange operating issues with menus and the accessories, it's been great for the first 1,100 miles. As always, I change the oil in any new car after about 1K miles to get rid of metal shavings/pieces in the oil & filter. Maybe overdone, but safe practice for less wear. I've seen some crazy amounts of metal in oil filters and on magnetic plugs.
Of all the cars I've owned in 40+ years, this is the most ridiculous set up for getting to the (plastic) oil drain plug ever. About 28 fasteners to take down the skid plate takes a ridiculous amount of time to do an otherwise easy change. Apparently Audi wants to sell oil changes or engines as they recommend 10,000 mile for the first one and make even experienced mechanics' life way more difficult than necessary. Why not put a small moveable door in the skid plate for quick access to the plug? This would save a LOT of time and aggravation. New member and already ranting, but a very simple solution could fix this easily.
Why don't you just cut a small hole for the plug?
You might also consider an aftermarket metal plug with an included magnet. I'll bet someone out there makes one.
Wouldn't surprise me. I've been doing that for a couple years on my M3.
But I recently have a failed oil level/temp sensor and have a Hella sensor in hand to replace the one in the bottom of the sump. And which requires me to remove the plastic underbody panel as well as a ginormous aluminum reinforcement plate to get to the sump. At least on the E46 M3 there is a small hole/door to reach the drain plug so I'll drain the oil from the sump before I do the sensor replacement. One sensor in 15 years and 110K isn't a big deal.
Keep in mind one needs to loosen the bolt/cover on the oil filter cartridge holder to allow the oil in the filter/cartridge holder to drain into the sump.
Ah, second A5, first wife.
Dark Metallic Navy, light grey interior, driftwood accent, B&O, basically loaded.
Came with light grey mats....not good. Got her some dark grey Lloyds mats.
My kingdom for a simple dipstick.......
Thanks, good thought, but it's also a plastic sump. .
Think I'll buy an extra plug anyway.....it's removed with a flat blade screwdriver and it's a quick release thread.
Only thing I've seen like it are golf shoe spikes.
Bizarre.....
Bizarre.....
