Embarrassing, but can't find where to check the oil!
Hey All,
Very embarrassed here, but I can't find where to check/insert the dipstick I bought.
Here's a photo from the owners manual with an arrow pointer to where it should be:
Here's a photo of that part of the engine compartment:
As far as I am aware, the B9 generation does not have a method for manually checking the oil. Everything is done electronically through the MMI.
Also the oil cap is on the opposite side of the engine bay (just left of the center). So I would assume if there is a way of checking the oil, it would be around that location.
Club AutoUnion
It’s on the drivers side of the engine bay. After you pull the engine cover off, there is a rubber “plug” that you remove — and save, just in case — and the dipstick installs in the tube that you pulled the rubber plug from. It is kind of buried in the front of the engine, but you’ll see it with a good flashlight.
This is what the plug looks like — the right end is what you’ll see sticking out of the dipstick plug — just pull it straight up to remove it.
Dipstick Plug To Be Removed.
I hope this helps you locate the tube / plug.
— John
Garber, 99.9% of Audi drivers won't ever open the hood on their car. The oil level is displayed in the car's MMI system. The car is constantly checking the oil level as you drive. IF you open the hood, it will take some miles of driving before the MMI can display the oil level.
Club AutoUnion
As always — YMMV.
— John
If you are serious about checking the quality of your oil then use blackstone to run oil reports. Look and smell aren't going to tell you anything meaningful outside of "yup that's oil".
Also, unless you are tracking the car often or tuning the engine output above the stock spec, there's very little observable benefit to changing the fully synthetic engine oil more often than recommended.
NOt to mention the sensor WILL and HAS failed on my 2003 M3
As an “old school” car owner, I bought the dipstick to not “just” visually measure the oil, but also to physically see and smell the oil. Electronic gauges may be fine for checking the level — but they don’t increase my comfort level like my eye and nose do, especially when the manufacturer specs out a 10,000 mile interval between oil changes.
As always — YMMV.
— John
Good thing I have an oil dipstick. I'll do the sensor change next oil change in June or July. Like I only put 5-6K miles on the car a year.
A 15 year old BMW is related to the oil sensor in a 2018 Audi how?
I've owned 4 VAG cars over the past 6 years and never seen or heard of a failed oil sensor.
As always — YMMV.
— John
As always — YMMV.
— John
I drive almost all city in Northeast traffic, worst type of conditions for oil, I had my oil tested a few times at 10K miles and came back good. Coming from dino oil, I too had my doubt regarding modern day synthetic oil but have been proven wrong. Took me a while to convert to 10K oil change interval and feel comfortable about it but I sure would like to look at the condition of the oil in between oil changes.
Club AutoUnion
I am from the old school much like you and much rather have a dipstick but I haven't thought about buying a one yet. Looking at it and touching it can also tell you if the oil is contaminated, smelling it can tell you if are running hot. I drive almost all city in Northeast traffic, worst type of conditions for oil, I had my oil tested a few times at 10K miles and came back good.
With a $70,000 vehicle at stake, dropping the money for the dipstick made sense to me — and it may not for everyone — and I learned old school lessons about an “ounce of prevention is worth a pound of cure” when I started driving.
— John
