EMD RS Grille/Front Parking Sensor Issue
I had a RS style grille (mine is from EMD) installed in my A5 SB this past week and all was well. However, today I got in the car to head out and the front driver side sensor kept going off intermittently. I am guessing this means I’m going to have to go to the dealership to get the sensors calibrated (and cost $$- since it won’t be warrantied). Has anyone, with a modified grille. encountered this type of issue and/or had it resolved?
Happened to me too. I was able to resolve the issue and you will not need any calibration.
Things to check:
1. Ensure the sensor harness wires are not too tightly pulled.
2. Make sure the sensor is properly aligned in the provision of the RS grille.
Things to check:
Excellent suggestions, thank you. It could have been a grommet or alignment issue, but a quick spit shine on the sensor seems to have fixed the problem! The sensor looked clean, but as @BreedsAs knows, we got a lot of rain in DFW Fri/Sat. Maybe while I was giving it a quick clean, it could have set the grommet or slightly aligned it again. Time will tell, but hoping it’s fixed!
Club AutoUnion
My EMD grille went on Wednesday and so far no problems. I did scour the various threads devoted to this grille install and made sure to follow all the advice posted (Thanks to all that came before!).
Cv640pilot (06-21-2019)
Have the same problem, but EMD didn’t even bother replacing the grill or the sensors even after numerous emails of “follow ups”. I even bought new sensors coz mine intermittently comes back on when that side gets wet and water sits there. I believe it isn’t the sensor it’s the actual grill. The sensor doesn’t sit snug and it’s also a bit cockeyed which causes false alarms. It’s a bad grill mold.
@Nikon1 - looks good! Hope you don’t have a sensor issue crop up this week
