EMD RS5 Grill Installed > B9 S5 Prestinge
#12
I left the foam piece off. Initially I tried whittling away what I thought might provide enough clearance but then realized that it's simply too thick unless you want the new grille insert to be mashed up against it so much that it deforms the grille itself. As mentioned in my original post, just prep and mask off the crash-bar, paint it flat or satin black and leave the foam off.
#13
Your absolutely right about the removal of the tabs.... Holy cow I spend 50% of the install on removing those tabs, my suggestion would be remove 2 tabs, and walk away for 5 min cool down, otherwise u get so frustrated u might just break some tabs.... Thanks again to in_an_instant
#14
- "The tabs to remove the actual grill portion are an epic test of patience. The dude working on the S4 in the video is either a hacker, mage or has removed 1MM tabs. I spent nearly 50% of the entire install time working the old grill insert out. Take your time for sure".
#15
#16
Nice, yeah I could see the tacks helping a ton. The guy in the video seemed to be able to do it so effortlessly that I didn't even consider an alternate approach.
#17
Here she is .... Thanks for all your help with the install ( in an instant & BreedsAs ) I'm contemplating whether to install the quattro lettering on the lower part, the letters are in Red color... any thoughts ? my kid thinks it looks good all Black
Jeremy Schumacher (09-23-2019)
#18
Club AutoUnion
I vote with your kids - but they have much more influence than me!
Looks good. Hoping to get mine installed in a week or two. Where did you get the black Audi Rings? I think i’d like to do that to mine, once it’s installed.
Thank You.
— John
Thank You.
— John
#19
So the vendor offered me a choice of Chrome or Black rings, I chose the latter... You might want to install the rings before you install the grill,
#20
Club AutoUnion
Is yours the EMD grille or another brand? When I ordered my EMD, it was via their web site so I was never offered a choice. I have the genuine Audi Black Rings, But I’m not sure they will fit. And I know what you mean about installing them prior to installing the grille.
Thanks for the reply!
