Engine Start/Stop System
Believe it or not, I got the car a few weeks ago, for some reason (maybe extreme low temp, or i always have the heat on, located in boston area so it was brutal in the past many weeks) the Start/Stop System never kicked in. Today it was almost 40 degree, and i was driving my car, i noticed that the little A sign turned green and had "ready" note right next to it. so here's my question:
- It was very noticeable when the engine restarted, and it's not very instant. It made my initial acceleration very NOT smooth. Do you guys have the same feeling? - When the engine was shut off, it seems that my steering wheel is also locked up - is it normal? - Anyone from northeastern area had the same thing that in the past weeks this function never kicked in, until this warm week? - I personally really don't like this feature and got annoyed immediately when i realized that it defaults back to "ON" even though i shut it off for my last trip. What do you guys think about it? - What are some of the best practices regarding this function? Thanks in advance! |
I have mine programmed off since the car was one week old. It can be done with VCDS.
-Eli |
Originally Posted by TJEli
(Post 25094054)
-Eli |
(Post 25094054)
-Eli I now bump the transmission in sport mode after I start which then leaves it off so that's what I use, and of course in dynamic it's auto disabled as well... |
I find it annoying as well. Due to weather, I have to keep my car in Comfort mode; however, I have noticed that when I barely depress the brake petal to keep from moving the auto shut off mode deactivates. Also when it was brutal weather and I had my heat and heated seats on full blast it didn’t turn off the engine.
I also figured that as long as you leave climate control system on, the start/stop system almost never kicks in, especially if you leave defrosting on. and yes, going other driving modes deactivates it as well. I don't mind leaving the climate control system on all the time, so the feature all of a sudden doesn't bother me that much......
not that i hate the purposes behind it, it's just that when the engine kicks back in,it's too noticeable.... |
In the Boston area as well. Have not yet ever had the system turn on (thankfully) and I got the car back in September...
Originally Posted by buckem
(Post 25094215)
Originally Posted by Momenting
(Post 25094223)
yeah i hope it's true that as long as the climate control is on, start/stop is off, so we can easily keep it that way....
seats keep it from functioning but just the AC doesn't |
I went into it open minded. I did not like it at all. The lag when pulling into traffic is unnerving.
As far as disabling this feature with VCDS.... Go to module 08-Auto HVAC, Adaptation, scroll to AC comfort parameters for start/stop. The stored value was 5. Change this to 0 and save. This will keep auto start/stop OFF as long as the climate control system is ON. (Who turns it off?) -Eli |
