Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
Extended Term protection worth it?
Old 01-30-2019, 07:56 AM
  #31
JD15's Avatar
Originally Posted by The G Man
Even with the pads and rotors for both axle, you looking at about $2000. Add=left 3 sets of wipers which cost about $300, front wheel aglignment $200, fluids $50, built in profit $450.
Even that number is being generous, as OEM quality wiper blades can be purchased for no more than $50 and there is no reason to replace the blades more than once over four years.
Old 01-30-2019, 08:40 AM
  #32
Rius's Avatar
Originally Posted by evanseric21
Here is a list of all the packages I was offered and what I selected. I went with Audi Care and Multi-Shield Protection. I really only wanted Tire/Wheel Protection and Windshield but those two were more expensive separate so I just did the package deal which includes a lot of other stuff(that I wont use).
That's interesting the prices they are charging you is different than what I got quoted from my dealership. Maybe it's because you have an RS5 vs S5? I don't have the ability to post a screenshot right now but I was quoted $1989.00. The brochure also states that "as the part wear out, they will be replaced", which to me implies the pads will need to be actually worn out before they replace them unless the dealership is being sketchy and just misreports their numbers.
Glad for all the information coming out on this so far, definitely makes me more skeptical of getting any extended warranties/coverages from dealerships.
Old 01-30-2019, 08:52 AM
  #33
evanseric21's Avatar
Yeah that is odd. What vehicle did you purchase was it an RS5? How much did they charge you for Audi car? They charged me $999. I wonder if the amount for Term Care is based on the vehicle you are purchasing.
Old 01-30-2019, 09:11 AM
  #34
Rius's Avatar
I bought a 2019 S5 SB. They also charged me 1k for audicare. I think since audicare is actually like an "option" that you can get they can't really vary the price on that. Like if you were to spec out a car on audi's website you can select audicare as an option. Kinda sucks they increased the price on MY2019s to 1k
Old 01-30-2019, 10:00 AM
  #35
Yeah I see your point with Audi Care. I purchased a 2019 RS5 Sportback. This could be why my Term Care price was quoted higher. I don't know this for sure though. Would definitely like to find out. Anyone else purchase an RS5 and know the price they offered for Term Care?
Old 01-30-2019, 10:10 AM
  #36
The G Man's Avatar
RS5 have different brakes than the S5 I assume and the RS alignment should cost more as well.
Old 01-30-2019, 10:15 AM
  #37
Permanent S Mode Member
MH62's Avatar
You need to consider FD-Warranty for better pricing. Here are some fresh S5 numbers obtained from Troy at FD-Warranty.
Vehicle: 2018 - 2019 Audi S5 with less than 10,000 miles.
Audi Pure Protection, Platinum w/ $100 deductible:
5 yr / 100K - $2865.00
6 yr / 120K - $3835.00
7 yr / 70K - $2575.00
7 yr / 100K - $3750.00
7 yr / 120K - $4070.00
8 yr / 80K - $3040.00
8 yr / 100K - $4070.00
8 yr / 120K - $4390.00
10 yr / 100K - $4145.00
10 yr / 120K - $4610.00
Other Option: Fidelity Platinum w/ $100 deductible:
7 yr / 70K - $2355.00
7 yr / 100K - $3275.00
7 yr / 120K - $3579.00
8 yr / 80K - $2628.00
8 yr / 100K - $3554..00
8 yr / 120K - $3848.00
10 yr / 100K - $3624.00
10 yr / 120K – n/a
Fidelity plan is the same plan as the Audi Pure Protection plan without the Audi name/logo on it…and coverage would be good at all Audi dealers in the U.S.
For Term Care (brochure attached):
Term Protection:
4 yr / 50K - $990.00
5 yr / 60K - $1980.00
6 yr / 72K - $2545.00
Term Protection Plus:
4 yr / 50K - $1065.00
5 yr / 60K - $2330.00
6 yr / 72K - $2945.00
Term Protection w/ Rotors:
4 yr / 50K - $1605.00
5 yr / 60K - $3540.00
6 yr / 72K - $4105.00
Term Protection Plus w/ Rotors:
4 yr / 50K - $1680.00
5 yr / 60K - $3890.00
6 yr / 72K - $4605.00
File Type: pdf
Old 01-30-2019, 11:52 AM
  #38
James P.'s Avatar
For what it's worth, my B8.5 RS5 is on it's second set of front pads and rotors with only 42,000 miles, mostly in the city. i.e. they lasted only about ~20,000 miles . The dealer replacement price was in the region of $2300 for the front pads + rotors and the rear pads/rotors will need doing pretty soon. If you can get the Term Care Select for $2,000 that seems like a good deal to me. I have no idea if the B9 RS5 will go through pads/rotors as quickly as the B8.5, but I will definitely be considering the Term Care package, assuming the price is about $2k, rather than $3k as evanseric21 posted.
Old 01-31-2019, 06:47 PM
  #39
Solar3's Avatar
Picked up a RS 5 SB today and this post was incredibly helpful in going in with a price in mind for the Term Care. For me personally I only really was on the fence for the Term Care w/ Brake Rotors and didn't plan on picking any others (hopefully I will continue to avoid pot holes...). The initial quote for the Term Care was just over $3k, which I'm pretty sure was for the 48 months (although in retrospect I'm not 100% certain). As soon as I started saying that I may not pick anything (outside of Audi Care) I was offered a $1,591 quote -- this is for Term Care /w Brake Rotors coverage for 48 months.
It does definitely cover the replacement set for front/rear pads and brake rotors (w/ the Brake Rotors coverage) due to wear and tear.
It's impossible to say whether I'll end up in the money by the end of the 4 years but at that price I thought it was an acceptable risk on a car like this. It does seem reasonable to have to get through replacing a set of front/rear pads and brake rotors within that time for a daily driver to/from downtown.
Obviously whether this is worth it or not is a personal choice, but at least in this case there was quite a bit of a possible discount even on a RS 5 SB.
Hopefully this info is helpful to others as well.
-- Solar3
Old 01-31-2019, 07:54 PM
  #40
Rius's Avatar
-- Solar3
Thanks for sharing man! Hopefully this will help others. It does seem like the default price is closer to 3k for an RS5 compared to 2k for an S5. Really glad to hear you got them to come down 50% on the price. At that point I think it would definitely be worth it for the peace of mind.
Quick Reply: Extended Term protection worth it?
