Finally - 035 R-ARB
Finally - 035 R-ARB
034 that is. My GF ordered this for me on December 9th as a Christmas gift. Well, just arrived and in queue for install tomorrow. If anyone has any knowledge to share, let me know.
The bushings, grease the hell out of them both inside where the sway bar goes through and outside where mounting brackets hug em. My bushings failed after a few thousand miles and initially squeaky noise over speed bumps...I think the shop that installed the sway did not adequately grease them and they cracked. I replaced the bushings and greased the s#$t out of them and now they are holding up well and are quiet. I did hear back from 034 that we should use the grease zerk fittings to apply grease every 10k miles or so to the bushings.
Hope this helps, I do love the sway and so will you!
Do you have S5 or S5SB? On the SB it really helps to have a full lift and to get this extra brace / exhaust out of the way if doing yourself. I could not for the life of me snake the OEM sway out when on jacks/ramps. Ended up getting it installed along with my AWE Touring exhaust.
Wow! I now have a few more miles on the 034 ARB and have had a chance to check it out on a few of my favorite twisties. I am amazed at the improvement in handling with just this small upgrade. Having come for a long run with BMW's, I initially found the handling of the S5 a little less engaging and fun than either my 540i or 535i M-Sport. Well I can honestly say that is no longer the case and highly recommend this upgrade to anyone interested in an improvement in handling performance.
bd s4
07-05-2007 07:05 AM
RoberTT-WWCD
02-14-2005 04:24 AM
Projekt 8E
07-28-2004 05:01 PM
