Help Sorted Powertrain Bus Issue
Hi,
just scanned my vehicle and I have the following fault which I cant seem to resolve so I am hoping to get some additional pointer in the right direction. It the Engine 4332 Powertrain coding issue.
has anyone got some ideas? the ABS and Airbag controllers don't have any label files and suggested to contact Ross Tech. Its a Audi A5 2,7tdi Coupe
Tuesday,11,June,2019,14:28:56:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
www.Ross-Tech.com
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CGKA) Labels:| 059-907-401-V1.clb
Part No SW: 8K1 907 401 A HW: 8K1 907 401 A
Component: 2.7TDI EDC17 X01 0008
Revision: 15X01---
Coding: 0114002C02070120
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM27TDI0118K1907401A 001012
ROD: EV_ECM27TDI0118K1907401A.rod
VCID: 2A5BB4A94DFF2E1AAB-807E
1 Faults Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [047] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 247182 km
Date: 2019.06.07
Time: 22:05:50
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 68 °C
Intake air temperature: 18 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.240 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Acceleration: 0.000 m/s²
ACCI a Des: 0.000 m/s²
ACCI st State-Bits 0-7: 00000011
Cruise Control System (CCS): status-Bits 0-7: 00000100
ACCI st Brk Err mp-Bits 0-7: 00000000
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K0 927 155 AG HW: 0AW 927 156 G
Component: 0AW 27 TDIRdW H01 0002
Revision: --H01--- Serial number: 0000000009
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A01015
ROD: EV_TCMVL381_A01.rod
VCID: 78FF5EE1C3D34C8AED-802C
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 1A0500
VCID: 78FF5EE1CBD34C8AED-802C
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 011000
VCID: 306FA6C1632354CA65-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000036623012
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0208000042950002
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0102.08.080558
Coding: 36060000
VCID: 428BFC09DD8FD65A83-8016
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000193244
Coding: 260050914034AF010009000000005D5D001D43880001014100 0000
VCID: 2F6DA5BD7E1D4B327C-807A
Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110808 H11 0040
Serial number: SWFBIE 0000184
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10215571
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000808080020
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52930821206728
Coding: 000101
VCID: 3A7B84E9B55F9E9ADB-806E
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD189N86
Coding: 30323433363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C7782F1B76BA0AAC9-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME3D44115BF
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME2256015B6
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME0D0343189
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME0D030C36F
Crash sensor for front airbag: driver side:
Serial number: 63732SME6A362109-
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME00063F18X
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HH7000EZ
Coding: 000032
VCID: 3D718FF5A471A9A2FE-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H30 0224
Revision: 00000000 Serial number: 9D654GC88
Coding: 2F07000002002600010000
VCID: 3B7581EDBA65A792C0-806E
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G087298074
Coding: 000303
VCID: 4683E019F1A7EA7AAF-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 1803536A270708
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 A HW: 8K0 959 793 A
Component: TSG FA H09 0149
Revision: Serial number: ViG
Coding: 0110022240012201
VCID: 3E7388F9A977B2BAE7-806A
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112918991
Coding: 011B068200390400002000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 247194 km
Time Indication: 0
Date: 2019.06.08
Time: 16:28:43
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2000000
Coding: 0203010101
VCID: 6ED378B9B997023A37-803A
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 A HW: 8K0 959 792 A
Component: TSG BF H09 0149
Revision: Serial number: GeG
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000195824
Shop #: WSC 00000 000 00000
VCID: 3169A3C568295DC26A-8064
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
Shop #: WSC 06324 000 00000
VCID: 3467AAD1573B68EA01-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 C HW: 8T2 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1104837
Coding: 0502008001040D00035B070000
VCID: 387F9EE18B538C8A2D-806C
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
End-------------------------(Elapsed Time: 02:40)--------------------------
www.Ross-Tech.com
Revision: 15X01---
1 Faults Found:
P1647 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 247182 km
Date: 2019.06.07
Time: 22:05:50
Coding: 000001
Coding: 1A0500
Revision: 00002001
Coding: 011000
Coding: 36060000
Coding: 00FD11
Coding: 02532C
Coding: 000101
Coding: 000032
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 247194 km
Time Indication: 0
Date: 2019.06.08
Time: 16:28:43
Revision: S2000000
Coding: 0203010101
Coding: 0000001
Component: Display
AudiFX
11-12-2007 12:07 PM
vegasS4
01-16-2006 08:46 PM
Snow Trooper
05-02-2005 04:44 PM
TwinTurboTerror
04-04-2005 12:35 PM
