Homelink receiver
#191
For what it’s worth — Genie makes LED bulbs for garage door openers that filter the interference. They’re pricy though - $9-$10 each. I have four of them installed and they work well — but didn’t help with the issues I had with the range on the purple learn button.
#192
Good job PRGeno...amazing how persistance pays off...LOL!!! My Homelink programming went much better on my 2006 A4 Cabriolet...I had to do the 2nd part of the programming for the advanced coding, but only needed to climb the ladder and hit the Learn button once.
#193
I did not want to mention in the first post because I am still testing, Torchstar 1600lumen (100watt eq) LED they claim it's RFI minimized for garage door openers. Two interfered but with one it worked like a charm I could open the door from about 130ft. It appears to have become a bit unstable as it has warmed up. I will post again with results during the summer. Torchstar is pricey too.
#194
This has been driving me crazy ever since I got my B9 RS5 a few weeks ago. I tried everything possible to get Homelink programmed, but nothing seemed to work. The problem was that my remote was not recognized by the system when I tried pushing it near the rearview mirror. Then, I randomly tried it outside in front of the hood and it worked the first time! I tested it a few more times, and sure enough, it works every time. If you've been having trouble getting your remote to be picked up by Homelink, ignore the instructions inside the car and try it near the front of your car, facing the windshield and leaning over slightly over the hood.
FYI, I have an old Genie garage with a red LED remote that has the rolling code function. So, I did have to do the second step and train Homelink using the program button on the actual overhead unit. This was after the button on the remote was recognized. Good luck to all!
#195
Ok everyone, I know this is the (anti-climactic) post you've all been waiting for!
Took my car to the dealership this morning - they worked with Audi TAC all morning and have a "fix" (I use this term loosely and you'll see why) that does allow successful programming and operation of the Security+ (purple button/antenna) garage door openers. The reason the remote can't program is because of interference from the lane change / blind spot assist radar in the rear of the car. Here's the workaround (and I'll preface this by saying do this at your own risk. The tech did have to clear fault codes out from the computer, so I'm not sure if those were caused by performing these steps, or other troubleshooting they performed):
1. Make sure the car is off
2. Pull the fuse for the lane change / blind spot assist (it's already out in the pic, but the spot is circled). It is the 4th fuse from the bottom in the rear driver-side fuse panel in the trunk. It's an orange 5 amp fuse, located directly above a 7.5 amp fuse.
3. Go through the programming process and sync the opener (we initially had to back the car into the driveway so it would be closer to the opener since the transmitter is near the rear bumper)
4. Test it out a few times
5. Turn off the car
6. Put the fuse back in.
I opened and closed mine about 5 times, and had descent range. So far it seems to work. In a perfect world, I'm guessing Audi would update the car's software to disable the radar during programming (that would be my ideal fix at least), but I guess we wait and see. I don't have any paperwork yet, so I can't reference and type of bulletin number or anything.
5. Turn off the car
Oh man, this works like a charm!! Thanks so much for posting.
I have an 18 S5 Sportback Prestige and was having the same issue with programming my purple button garage door.
The following 2 users liked this post by krsidodd05:
farleto1 (08-14-2019),
Frank Brinkmann (07-02-2019)
#196
5. Turn off the car
5. Turn off the car
#197
just received my custom ordered 18 s4, you would think this would be fixed by now, but no. did the fuse trick, worked immediately.
edit: the process will log an unconfirmed fault, no check-engine light. I cleared it anyways.
1 Fault Found:
26521 - Lane change assistant control module
U1045 00 [038] - No communication
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 76 km
Date: 2018.07.21
Time: 17:06:17
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 76 km
Date: 2018.07.21
Time: 17:06:17
#198
#199
Thanks!
5. Turn off the car
5. Turn off the car
#200
Once you do this, you may want to clear any faults that it throws via OBDEleven or VCDS if you have it. In my car it caused a lot of systems to become momentarily unhappy and it may make it harder to identify real issues in the future.
