MMI menu system hierarchy
#11
New '18 A5 sportback, in general love it so far. One strange thing is the menu system hierarchy. From the MMI home menu, scroll to Vehicle and click the MMI ****. It takes you to a sub-sub menu, the drive select. Then you have to hit the left button to go up one level.
i.e. from main menu (call that level 1), you skip down to level 3, then you have to say "back up" to go to level 2 with the left button. And why does it (arbitrarily) take you to drive select when there's a perfectly good hard button on the dash for that?
Is there any way to make the menus more sensible, level 1 to level 2 to level 3?
#12
Yep, that's my primary and maybe my only reason for needing to dig through that menu.
#14
The problem with this menu is that it doesn’t keep track of the last thing I changed - it always reverts back to the redundant drive select menu and getting back to the early/late lane assist setting is really quite a chore.
#15
That's what I thought at first too, and that may have made some sense. But NO it does NOT keep your last option. Go to vehicle, it always takes to you directly to drive mode. Left button up a level, select something else like Driving Assistants. Back to main menu or radio or somwhere else. Now back to Vehicle. Always takes you to Drive Mode, regardless of the last thing you did in there.
#16
#17
unless you want to take audi pre sense OFF every time you get in the car out of fear it will brake due to a false positive :\
but i got use to it now, and don't usually have to even look at the mmi to get to that setting., its sad cause it's like 14 steps to do this... ha
same with the 360 camera, i usually just go thru the extra 6 steps to get it to show when parking etc.
#18
#19
Ever since I stopped using my left turn signal while making a left turn I've had zero false braking from turn assist. I still use it for lane change though. What still bugs me is if a car in front is braking to make a right turn and you know you can just cruise and then go pass him, but pre-sense thinks you're about to collide and starts to false brake for you. That is a situation I still find very annoying.
potomacgolfer
A7
05-01-2013 09:35 AM
