obdeleven
obdeleven
fired it up today for the first time in few months. was looking to turn on the scandinavian drl's for my rear tail lights since I just had the clear blackline version installed. noticed that there are a lot more apps in the S5 section. even one for turning off the amber indicators which makes no sense since in the US they remain amber anyway. also added the RS5 g meter to the display as an option. it does display but doesnt do anything. I doubt that the S5 has a g meter in it but in case it does is there a way to turn it on? very pleasantly surprised that they added so many apps. even have the gear display available in drive or in sport mode now and it works.
There are g-meter apps for your phone https://play.google.com/store/apps/d...rfree&hl=en_US
Makes sense for people like me who swap with e-codes (easier than using long code in VAG-COM/VCP to disable amber indicators) or who tint/blackout the orange reflector
Just offering a solution since your car doesn't have the hardware.
>>To mute the Soundaktuator
A9 Structure Borne Sound
Adaptation 10
At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
Enter a value in the proper box (0% = mute )
>>show gear in D and S
02 - Transmission
Adaptation
“Single gear display”
Set new value to “D on/S on”
>>Increase Range of Comfort Window Open/Close with Key
46 - Central Module Comfort System
Long Coding
“comfort_operation_range_limitation”
Change from “active” to “not active”
Press and hold green check mark to accept
>>Confort Blink Cycle
Adaption
Turn signal control-freeway flashing: flashing cycles
Old value is 3 (for 3 blinks)
Disable Seat Belt Chime
Go to module 17 “Dash Board”
Long Coding -> “Seat Belt Warning”
Default is “Version 2”. Version 1” displays the logo without chime. “Off” turns off the logo and chime
Green check mark to accept.
