Phone Mount?
#21
Proclip
Appreciate seeing all the different options here. They all looked good, so I basically flipped a coin and tried the proclip out. It seems okay, I was worried about the adhesive being too sticky but it wasn't at all, and when I first put it in and I tried to adjust the phone the whole mounts popped out scratching the plastic piece that the clip goes under, but it turned out it was because I didn't put the adhesive part all the way in, I installed it better the second time and it's been fine. I like being able to have Waze on the phone, while having the iPhone (second phone) on car play for music.
#22
#23
Club AutoUnion
This is is the base of the ProClip that I have used in my previous cars. They have matching cell phone holders that attach to this mount - and they stock most older & current cellphones. I will be ordering this base in the very near future - IIRC, it’s $29 dollars.
#24
This is the one that I use. I'm very happy with it. It puts the phone in an ideal spot - withing sight, but not in your sightline so it doesn't become a distraction. It also doesn't interfere with any buttons or vents in this spot and doesn't get in the way of the passenger. It's also 100% removable if you don't use the double sided tape to hold it in place, although it does have a tendency to migrate toward the rear of the car without that adhesive. I used a piece of soft rubber underneath it to help it stay in place.
#25
#26
I have this one and am very happy with it. I have it mounted on the wide vent. The clamp is rubber protected and it fits perfectly inside the slats without scratching any of the surrounding trim. It is a magnetic mount so it can interfere with wireless charging if you place the metal place at the wrong location. I have to use the circular metal pad and place it towards the bottom of my Galaxy S7. I find that location a perfect balance between allowing wireless charging and stability on the mount.
#27
One more point about this mounting position - when plugged into the USB cable for charging or Android Auto, it's very easy to tuck the cable between the console and the passenger seat to keep it out of sight.
