Pothole destroyed 2 tires
#11
I would have thought the front tires should be newer since the car is has more weight on the front. From my experience with the B8 I couldn't tell if the front or back wear out faster but I rotated them just in case.
I feel for you, I hit a pothole once that broke not only two tires but two rims also.
#12
Club AutoUnion
#13
If the back tires let go in a turn, then they are the ones doing the steering. If you are going straight, it doesn't matter as much. It's a question of picking understeer vs. oversteer. Generally the latter is thought to be more dangerous.
#14
Permanent S Mode Member
I agree, traction in rear is more important. Just take it to the extreme, a car with great traction in front and poor traction in back will lose out in a race to a car with poor traction in front and great traction in back. I've raced karts on wet tracks with slicks up front and rain tires in the back but never the opposite, it would immediately spin out.
#15
#16
All,
I think you're forgetting the spec for uniform tire diameter that the Torsen system on the S5 demands. I don't know it off the top of my head, but depending on how much wear there was on the tires, he might need to get a full set so as to not cook his crown gear etc. It talks about this in the manual, but I don't know what the spec is.
#17
#18
This is correct - you need to check this requirement. Should be in your owners manual. I went thru this recently with my wife's TT which had one bad tire due to a road hazard. learned I needed to replace the whole set, but not recalling exactly how much variance is allowed. Check it out. If you're OK on the tread depth I agree with others that the new tires should go on the rear.
#19
From tirerack: AudiAs published in their vehicle owner's manual, "rolling radius of all 4 tires must remain the same" or within 4/32-inch of each other in remaining tread depth.
#20
Yes, it is, but the misconception is that more tread improves braking. It actually worsens it. Pure tire grip increases as the tire wears, believe it or not. That's why race cars use slicks. The tire tread reduces the amount of material on the ground. The only reason street tires have tread is to dispel water and trap snow. If the tread is too low and the car too fast so that not enough water can be dispelled, the tire starts floating on the water and traction is lost. Once you hydroplane, the worst you can do is to step on the brakes, so the ability to brake is the least of your worries once hydroplaning. So the most important thing is to make sure your rear tires do not hydroplane. Because if they do, you gonna spin out most likely. Hydroplaning occurs if the car is speeding up or already driving faster than the tires can get rid of the water, not when braking, and slowing down actually reduces the risk of hydroplaning because the tires have more time to get rid of the water.
