Pre-sense...
#101
Right, but you are probably able to add traffic sign recognition in the future.
Are you able to find the schematic / part number of the mirror mounted camera?
I'd like to see if I can find out what it's capabilities are.
Also, what reference are you using to produce this information may I ask?
The code would be just QK1
If you have the other type of camera it may have a different code.
#106
We are deducing that this type of camera is installed into Canadian models without ADAP.
It looks as though it can perform two functions: high beam assist and traffic sign recognition (with an upgrade at the dealership).
Those in the US have the other type of camera mounted higher up in the windshield.
#107
That lower camera almost looks like this "hidden" dash cam. I guess if your car doesn't have that lower camera this would be a good way to add a dash came that looks OEM.
https://www.aliexpress.com/item/Kamp...939912824.html
#108
Are dash cams illegal in some areas? I would think it is an easy way for the car manufacturers to add a factory dash cam since the hardwares are already there and all they have to do is program it in the mmi.
#109
A recent-ish Telsa update added "Sentry Mode" which basically added dash cam support that uses all the cameras that are already built into the car for auto pilot,etc.. to their cars.
#110
i am surprise it took car manufacturers this long to catch onto this, its a nice high profit margin option. Hopefully this will open the door for more build in dash cams.
