Pre-sense...
#142
what about the other side of the coin...
have there been documented case where the system should have activated but did not resulting in some type of contact.
the reason im asking, a couple of day ago i exited by parked car to see if i had a cleared a driveway behind me.
i had mistakenly thought i had put the car in park mode.. but when the driver door closed the car began to move forward at idle speed.
i jumped in and applied the brake with just a couple of inches before it would have made contact with a parked car in front of me.
i just read basic pre sense activates at speeds over 20 mph.
i have 2018 a5 prem plus and a 2018 q5 prem plus. i was aware i had pre sense but i didnt know about what types were available.
#145
Even after the self driving Tesla killed a woman, the regulators still have not given up on the self driving car concept. Its the sacrifice of the few for the greater good cause. As far as shutting off safety systems, forget about, Audi would be setting themself up for a lawsuit.
#146
I've had my car for 5 months now. I've seen the presense alerts, but never experienced the automatic emergency braking until about a week ago. From what I can tell, it happens when you are traveling under 40 mph, and you are not touching the gas or the brake pedal. Anytime I have even slight pressure on the gas or brake pedal when the presense warning pops up, it won't brake automatically. But if I'm touching neither pedal, it will brake on its own.
#147
My back-up auto-braking occurs when it senses the line between my driveway and the lawn. Most annoying.
Far more annoying is that it did not activate when it sensed my BIL's minivan and is costing me over 2k to fix. (his van)
#148
to be clear without any doubt im aware this is on me....i clearly mentioned i made a mistake, people sometimes do that.
i was just under the impression senors would detect an object and automatically brake.
because that has happened to me in the past while backing out of a parking lot spot, or parallel parking which is close to idle speed.
#149
It's a flawed system by any measure.
#150
For people complaining about the auto braking engaging when going in reverse, all you have to do is take the car to the dealership and they lower the sensitivity of that. Very simple fix.
