Pre-sense...
#41
I’m from Canada and i didn’t order DAP but the car has pre sense. It will have the rear cross warning which will automatically brake hard for you and also as i experienced it will pull the seat belt hard (according to a poster above) when you are close to being rear ended. I have a technik so I’m not sure if its excluded in the progressive.
#42
More of a reason that audi should have allowed its users to be able to deactivate it then. I couldn’t give up on technik because of the cockpit and bang and olufsen system.
#43
For the 2019, the Visual Cockpit is available as an option on the Progressiv. But not the B&O :-(
#44
I just see this in the manual that the different pre sense system behave differently depending onAudi drive select the mode selected.
Basic : The trigger times are adjusted depending on the mode selected.
Front : The reversible belt tensioner, the closing of the windows and sunroof, and the inflating of the side bolsters on the seat backrest may not be active depending on the mode selected.
Rear : The function is not active depending on the mode selected.
City : The function is not active depending on the mode selected.
#45
I had no such button in my BMW 328i or 535i. Is it just in their M cars? The problem is people turn it off and forget to turn it back on, that's why Audi defaults on.
#46
#47
I am not sure either, maybe it is that aggressive looking kitten you have on your avatar that gives out the image of a bad a$$ driver
#48
I'm not sure why that's a problem. Honestly, if you don't how know your car works and cannot drive safely without a litany of nannies, you shouldn't be driving at all. A simple "pre-sense off" icon would suffice. Instead, starting up the car is almost as complex as preparing an airplane for takeoff if one wants to defeat all of the "enhancements" to the driving experience (***, pre-sense, etc.).
#49
I wouldn’t want to turn it back on tbh lol.
#50
