Presenting the ColdFront™ Intercooler for the Audi B9 S4/S5. Available now.
Audiworld Basic Sponsor
Core cooling. Presenting the AWE ColdFront™ Intercooler for the Audi B9 S4/S5 3.0T. Get equipped here.
- 130% increase in frontal surface area over stock
- 83% increase in volume over stock
- Fits securely behind the stock crash bar, pure bolt-on
- All aluminum construction for maximum heat transfer
- Efficient bar and plate core construction
- Cast aluminum end tanks with integrated internal baffling for even flow across core
- CAD designed and CFD tested to ensure optimized flow in and out of core
- TIG welded and pressure tested assembly before leaving our facility
- No effect on OE radiator or A/C systems
- Utilizes factory hoses and clamps
- Designed and assembled in-house at AWE
- Perfect fitment, guaranteed
- AWE No Check Engine Light Guarantee
Cast aluminum end tanks with internal baffling, and a robust bar/plate aluminum core for maximum heat transfer render a 130% increase in frontal surface area and a massive 83% increase in volume over the factory intercooler.
Regardless if your vehicle is producing higher-than-stock boost levels, or you’re keeping it within factory spec, the ColdFront™ Intercooler solves any potential heat related issues. By keeping intake air temperature low, and pressure drop at a minimum, engine output remains consistent even when outside temperatures rise. The ColdFront™ will provide the safety margin needed in order for you to push the limit with confidence.
Important fitment notes:
There is no cutting required when installing this intercooler. The ColdFront™ Intercooler reuses the factory intercooler hoses and clamps.
What’s in the box?
Complete AWE ColdFront™ Intercooler with all necessary hardware required for proper installation.
Data
Josh Davis > Performance Specialist
AWE-Tuning.com > 1.888.565.2257
my email > facebook > twitter > instagram > youtube
How long are these backordered?
I ordered one through a popular authorized retailer and was immediately told it won't ship for at least 2 months.
Now I'm thinking about just cancelling.
Weird. Not true, couple weeks max.
AudiWorld Uber User
I see what you did here:
I did the same thing for more or less the same reason a couple years back
We've always had veins in our end tanks. Nothin' new here, per se
AudiWorld Uber User
It makes total sense for your application. When I did it in the picture above, the blower outlet was a little less than half the size of the radiator. Adding the vanes increased the total airflow through the radiator by 42%. I'm just glad you guys thought about it.
