PSA: Auto Start/Stop can be controlled by the brake pedal
Audi Driver & Enthusiast
Hey gang,
I've seen many folks complain about the inconvenience of manually turning off Auto Start/Stop (because they don't like the engine switching off when at a stop). Per the manual, the system will not switch off the engine unless sufficient brake pressure has been applied beyond the pressure required to hold the vehicle at a standstill. For example, in my normal driving, the system never switches off the engine at a stop unless I choose to depress the brake pedal hard with the intention of having the engine switched off temporarily. So, more attention to brake pressure will allow you to avoid manually disabling Auto Start/Stop during normal driving. Try it out!
I can control when the engine starts once the car had come to a complete stop, but I have a hard time making the engine not stop in the first place while coming to a stop... Maybe because my pressure increases as I come to a stop. Maybe I need to try to brake harder initially and then slightly decrease the pressure as the car comes to a stop.
Yep, it was pleasant to find out not to worry about turning it off every time.
I actually had more trouble modulating the brake pressure and not having the engine turn off with the Q5 and Q7. The Q7 would actually turn off as I was coming to a stop around 2 mph, not while I was stopped, and it felt like I was just learning how to drive because it would jerk the whole vehicle.
The only time I hit my start/stop button now is when I know I will be doing a quick stop to get out because then it would put the car into accessory mode.
Club AutoUnion
I still find it easier to just press the *** button as my finger leaves the Start / Stop engine button. Muscle memory is a wonderful thing.
— John
— John
Even easier to just rock back the gear shifter twice...don’t have to worry about over “pronating” the pointer finger! all kidding aside, recently I have left the car in dynamic / drive, when getting out of the ‘hood so the s/s engages at long wait times / lights. Then I go back into dynamic / sport when further out.
Its hit or miss trying to stop with light brake pressure and not having the car shut off. I use this feature when I need quick accelaration, lighten up the brake pressure to start the engine while I am at a stop.
I’m having trouble controlling the brake pressure. I just posted this in a new thread “When I used to have my 2018 A5 SB, when I didn’t brake too hard, you could feel the first level of depressing on the brake pedal (not all the way down), so you wouldn’t trigger the Auto Start/Stop function to turn the engine off. Now with my 2019 S5 SB, it is pretty impossible to do that. I noticed that when the car is slowing down to 1-2 miles, it just shuts the engine off (see the green Auto Start/Stop icon pops up in VC) and would make this jerky stop. I feel that I don’t have the same braking control to avoid triggering the Auto Start/Stop function. I know I can disable it completely by pressing the button under the climate control, but I do like to use it sometimes depending on where the traffic lights are or traffic flow. I used to be able to do that with my A5. How come it doesn’t work so well in S5?”
I just used OBDEleven to cancel the *** function completely, but the A/C needs to be on which is not a problem since I always leave the A/C on. IMO, Audi should have set the default setting to off, and for those who want it on, they can enable it with the button.
Club AutoUnion
— John
