Removing Fender/Door Badges on S5 Sportback
Does anyone know if the S5 Door and Fender badges are applied with double sided foam tape or if these are installed with clips? If they are clips, can these be easily removed? I purchased a 2019 S5 Sportback with the BO package and I want to black out these badges by painting or wrapping as well. Any information would be appreciated!
Originally Posted by Bdb9184
(Post 25258968)
You could choose to get them wrapped black if you are not privy to removing them safely. I painted mine. |
Thank you for the information. This is very helpful! Maybe I will just have them wrapped for now.
Any insight to where the clips are located for maximum leverage to prevent them from breaking? |
Subscribing for interest....
Any one know how take these badges off?
Did anyone try plasti-dipping them?
Originally Posted by belzebutt
(Post 25285365)
It looks great and has been pretty durable over the last 1.5 years. |
Originally Posted by jamis
(Post 25285368)
I plasti-dipped mine, though I didn't remove them. I taped/masked around them and the surrounding area of the car to avoid overspray.
(Post 25285390)
I was thinking that would be by far the cheapest/easiest solution. Any tips? Did you have to patiently cut away little details or something? And of course it's completely reversible.
Once it's masked, do several (I did 5 or 6) light coats. Don't over apply each coat. The first few coats will seem light/inadequate but it will eventually get the coverage you want. When you pull off the blue tape, be careful to not pull the plastidip off at the same time. |
