Removing Fender/Door Badges on S5 Sportback
#22
Yes I was thinking if you pull them hard enough the clips will just snap off and you can snap the new piece in after.
#24
#26
I posted a picture of the back of one of the wings that shows the snaps and the double sided tape that holds them to the fender/door.
https://www.audiworld.com/forums/aud.../#post25327745
plasticmoz (07-24-2019)
#27
I was able to get them off with a trim removal tool, didn't have to use a heatgun either. Taking the tape off will take some work but eventually it will all come off. The emblem themselves will likely break in the process.
#28
Hi. Has anyone done the side fender removal lately? Do you just pry them off? I want to replace with OEM black emblems. I don't care if i pry them off and they crack, i just don't want to damage anything on the car itself, like the holes or something where the new ones would clip in. Thanks in advance.
#30
Any new/additional info on the side badges? I will be ordering parts this week and want to replace them all at the same time.
I will heat up the side/fender badges and use dental floss to remove/cut the glue. After that Did you just pry it from one side (between the badges) until it popped out?
Thanks
Thanks
