SB Tailgate Close/Lock button intermittent issues
#11
I have issues with both buttons not responding intermittently. Sometimes pressing the close button does nothing the first time. Sometimes when I press the lock button the doors lock but the sportback doesn't move. Pressing it again one or more times (or the close button) eventually works.
Same response from the dealer: couldn't reproduce, no faults in the system, no TSBs.
All of these stupid little problems (slow clock, no automatic time setting, garage door opener issues) make it feel like I have the beta version of the car's software...
#13
Not sure if this is the cause, but sometimes when it doesn't respond to the button press I take a step back and then it always works. Dunno if its just a co-incidence or actually because I was too close to the hatch?
#14
I'll try stepping back the next time it doesn't close.
#15
Unless the car has become self-aware (ha), it's gonna need a sensor for that, and I don't think there is one. If you have stuff piled too high in the back, the motor will sense near the end of the close the higher current needed (or maybe position error), and reverse back to open. (It was a while ago, can't fully remembered if it stopped or reversed, but I think it reversed.)
#16
#17
Another data point:
I just had another instance of the lock button not working, so I tried moving around and opening and closing one of the doors. None of that worked. Then, without moving, I took my keys out of my pocket and held them away from the car at arm's length and the button worked.
#19
I have had the same problem where I push the lock and nothing but push the trunk close button then lock with key fob works. Over the last year I would guess it has happened 4 or 5 times so it hasn't been a big deal to me.
#20
I dont know if it is related, but my 2018 SQ5 just had its first service and they told me the rear door had a software update recall due. It seems to still not work most of the time when I press the "lock" button. Trunk button always works fine.
