Top view camera select and making it default
I like the top view camera when backing out but every time I select it works only for a time the next day the setting goes back to graphic view. Is there a way to save it permanently so always shows 360 view? Btw I did press select and 1 on the door
your camera view changes?
Mine stays on whatever camera view I set it to. |
Unfortunately yes, it defaults back to graphic view after 12hrs or couple cycles of turning the car on and off.
Originally Posted by Only_S5
(Post 25023421)
Mine was set to the graphic view as well. I had to change it to camera view within the settings of the Parking Assist.
Originally Posted by amademann
(Post 25023444)
Are you saying you're able to get top view as well as the backup camera at the same time?
Originally Posted by JRuby2004
(Post 25023536)
A nice feature too in that topdown 360 view is if there's cross traffic behind you it draws a very visible arrow with the direction of that traffic, etc. |
(Post 25023421)
Originally Posted by chucktu
(Post 25023610)
Yes, mine is doing the exact same thing. I have been through every setting I can find and just can't get the overhead camera view to stick permanently.
