Top view camera select and making it default
I like the top view camera when backing out but every time I select it works only for a time the next day the setting goes back to graphic view. Is there a way to save it permanently so always shows 360 view? Btw I did press select and 1 on the door
That's weird, mine always goes to the camera image (top view) when I put the car in reverse - it does that because I set that as the default View in the Parking Aid menu. See page 148-149 of the manual. Did you try this?
Yes there's a setting buried somewhere you have to change to make it camera view to start. Seems stupid they made the sensor view default because the camera view gives you that info and a visual 360
A nice feature too in that topdown 360 view is if there's cross traffic behind you it draws a very visible arrow with the direction of that traffic, etc.
Mine has stuck with the rear camera view since day 1 so not sure why yours keeps reverting back. Will check later today and see if there's some hidden setting.
