Wheel size
#11
Thanks man! Guess it is a bit early for snow tire talk, but always keeping an eye out for sales. Btw, didn't know 18" tires last longer than 19"?
#12
Never too early...Depending on the option could take some time to get everything ordered. That's a bit of a general statement, a lot of variables at play...Should be able to get more tread on an 18" snow.
#13
I think I will get one of the 19" options....just looks so much nicer with 19" wheels imo.
#14
I got some Vorsteiners via vivid racing. Found them online. VFF 103s in black with red center caps. 20x10 +30. They said they'll fit. Going to wrap them with 275/35/20s. Michelin PS4S. Will post some pictures once I get them installed in the coming week. Wheels and tires should get to my installer early next week but won't install until next weekend.
#15
20x10 45 offset
Hi I'm trading in my 2014 audi A6 3.0T and getting a 2018 audi s5 sportback.
My question is will my 20x10 45 offset wheels fit on the new sportback?
They fit perfectly fine on my a6 with stock 255/35/20 tires.
Any help would be greatly appreciated!
Thank you
Thank you
#16
You'll probably hit the steering knuckle too.
#17
Yes, the only thing that may make them fit is a spacer kit (with longer wheel bolts) and the proper tire size.
#18
Thank you for your responses and help.
Would a 10mm spacer make them fit?
Also would it be safe as long as I get hub centric spacers with longer bolts? No vibrations and such.
Thank you again
Thank you again
#19
Sorry. Also if that is able to make them work. What tire size would you guys recommend?
255/30/20
255/35/20
265/30/20
Without any rubbing issues and least amount of change in speedometer.
Thank you
255/30/20
255/35/20
265/30/20
Thank you
#20
Hi guys,
Just wondering if these will fit the 2018 S5 Sportback. That offset has me worried. Also, would I need spacers to make them flush?
20x10.5 et27 square set up 5x112 bolt pattern 66.6 CB General G-MAX AS-03 90% left 255/35/20
Thanks!
Thanks!
