Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
Wheel slightly off center after alignment. Would you go back to have them fix it?
Old 03-28-2019, 04:12 PM
luder888's Avatar
Default Wheel slightly off center after alignment. Would you go back to have them fix it?
Finally talked my dealer into giving me an alignment + ACC calibration under warranty. Now I notice my steering wheel is slightly off center while the car goes straight with hands off the wheel. Is this something you'd have them fix? They already dislike me enough. You can see better if you look at the left/right stalk position vs. the steering wheel.
Old 03-28-2019, 04:25 PM
Tainui's Avatar
Absolutely, yes.
Old 03-28-2019, 04:37 PM
KevinGary's Avatar
I would bring it back
Old 03-28-2019, 04:42 PM
bpp
bpp's Avatar
Do it.👍👍
belzebutt's Avatar
Hell yes.
Old 03-28-2019, 05:43 PM
Tony M's Avatar
I put up with a similar offset for the last 6 months I had my previous car. In retrospect, I think I was silly (or maybe lazy) to do so.
That will be a constant minor annoyance that will nag at you and it's perfectly reasonable to get it adjusted.
Old 03-28-2019, 07:41 PM
J. Patterson's Avatar
Should be corrected. Your stability programming ( ESP) is affected by an off center steering wheel. Yours is not off much but still——
Old 03-28-2019, 07:58 PM
luder888's Avatar
I'm having a moral conundrum. I don't know if I'm pushing it too far. I initially went in and complained about Pre Sense, but they refused to give me an ACC calibration because of my custom grille and wanted $599 for it. But then I showed them an invoice from 8 months ago from a different dealership that my car had a history of pulling to the right (they fixed it back then by rotating my tires) and I want my alignment checked under warranty. They told me they checked my alignment but it was a lie. Confronted them with proof that they were lying, and eventually they agreed to actually do an alignment and part of it is the ACC calibration.
So now they did all that, fell down a rabbit hole, and I'm going to back essentially for them to repeat it all over. As far I as I understand, centering the wheel is essentially another alignment and all the driver assistant features will need to be re-calibrated... Man do I miss the old days when you can just pay $50 to get your car aligned...
This is my 2nd dealer, and they're no better than the first. I might have to try a 3rd dealer. Why is it so hard to find quality people to work on your car?
Old 03-29-2019, 06:18 AM
John Harry's Avatar
Because we don't show respect for jobs that don't require a college education.
Old 03-29-2019, 08:10 AM
belzebutt's Avatar
So the guy didn't do his alignment and then lied about it because we don't show enough respect for his job? That's BS, but I did see that meme with Mike Rowe from Dirty Jobs. It's the free market man, if you pay these people enough someone will do the job and do it well.
If you've already complained then you can always get a $100 4-wheel alignment at some other place, but are you telling me that on the S5 every single alignment requires an additional hundreds of dollars in sensors calibration?
Quick Reply: Wheel slightly off center after alignment. Would you go back to have them fix it?
