Why no headlights washer on the '18 S5 SB
#13
I just noticed this, and checked mine, and they aren't there on my S5 SB. then saw this thread. I used to find them handy in the ice/slush/snow in the winter on my A6, but yes, they were a point of failure. And as things melted after a run and using them, they would drip/melt in the garage. so I guess I'm ok with not having them. Where I live now, there wouldn't be much use for them anyways.
#15
Had them on my Golf R, not sure they actually did anything other than spray liquid on the lights (which didnt clear them up)
Entirely possible Audi decided the headlights put off enough heat not to need them, not sure on that though.
#16
LED headlights put out less heat than Xenon/Bi-Xenon, if any. All mine did was spray the hood.
#17
While inherently true that per lumen LEDs take less power to run, there's no way of knowing for sure that the LED headlight assemblies draw less power without knowing the design specifics.
#18
Club AutoUnion
Properly designed LED “lamps” dissipate the heat generated via the heat sink that the actual LED is built on. For anyone that has pulled their Factory puddle LEDs and been rather amazed / impressed by the heat sink on the back of the assembly, these are well designed LED assemblies.
The heat coming off the front of the properly designed LED light is negligible.
#19
They're on the Matrix LED lights as the high-beam would blind other road users unless the light pattern is dispersed properly. If there's too much crud on the headlight lense then the theory is that the refracted beam pattern won't be correct and therefor on-coming road users could be blinded. That's the theory... how much of that actually transfers over to the real world is another matter.
#20
