02 Allroad front brake pad job...
Hey guys,
I have researched on how to change the front pads, but allt the links I seem to find are for the A4. Anyways, do I need any special tools to do the fronts? I see there is a hex key needed for the front. What size exactly do I need? Are there wear bars on the pads? My icon came on the other day. I'm just wondering if I have a little time. I hear no squeaking or grinding. I'm looking to do NAPA pads. Any recommendations? Prices would be appreciated too. Thanks guys.
Mike
Mike
changing pads in the front of an Allroad is probably the easiest brake job I have ever had, once the car is up & the wheel is off all you need is plyers & a flathead screw driver. The only write up I found was for a B5 S4 since they are the exact same brakes we have.
here's a step by step with pics: http://www.s4girl.com/Gallery/StockPadHowTo
Don't do OEM pads, they really really suck. OEM pads are the source of rotor warp like symptoms due to excessive dusting that settles on rotors.
Go for Akebono ceramics or other comparable pads. I am sure you will find lots of recommendations on this site if you search.
How difficult is it to short the pad sensor? Is it simply taking a short piece of wire and connecting the 2 pins with it and taping it up? I may do the Hawk HPS. Are there wear bars on the Hawks since the sensor will be bypassed? Are there wear bars on the stocks? Who has the best pricing for the Hawks? Thanks for the help guys.
I did the following in my old 98 A6 Avant. Once I removed the pads, I hammered the left over pad compound until it cracked upon when the sensor part just separated and then I tied the dangling part (past the holding bracket) of wire with ZIP tie around the wire itself.
Worked like a charm.
I don't think you can just short the wire (I might be wrong though) as I believe there must be some defined resistance (not zero ohms a shorted wire would provide) on the wire.
Also, I bought Akebonos ceramics and can be more pleased with the pads. Excellent stopping/fading and seriously NO DUST - plus they have pad sensors.
I just called my local dealer to see if my fronts are the 2 pad or 4 pad set up. He told me a had a 2 piston set up. I'm assuming I need the 4 pad set. Does this sound right? He said he couldn't tell by the diagram in front of him if it was a 2 or 4 pad set up. Can someone give me more info on how to "short" the pad sensor? I may do the Hawks. I can't believe they want $190 for OEM pads!
