Wheel fit question
Old 03-24-2014, 12:57 PM
Tahoesilvers4's Avatar
Default Wheel fit question
Looking at a new set of rims for my allroad. Ran across this ad: http://reno.craigslist.org/pts/4387368426.html
They are 5x112 which I know will work but the offset is 32. Anyone know if these will work?
A little nervous about going with 19".....
Old 03-30-2014, 07:37 PM
Linda Williams's Avatar
unless something has changed, do a quick search on 16" steel wheels...you'll see that there aren't many that fit. in fact, I think people decided the wheelers off-road steelies are pro comp 87 so that's pretty much your only option.
Old 03-31-2014, 05:28 AM
all(over)road's Avatar
2 would be OK out back but up front the offset is too low....I would say you need spacers to make it work properly, either a 5 or 10mm.
I run an et29 19x9 RS4 rim sometimes, with 255s....no problems out back, but it is a very tight fit up front and the inside tires rub on the shock once in while, especially when on level 1. I think I'd be better with a 245 tire on the allroad, but then they wouldn't be right when I switch them back onto the RS6.
Old 04-07-2014, 09:06 AM
http://www.allroadfaq.com/content/wheelstires.shtml
This old (but good) fit list can help out...
tibbar
9
03-08-2008 01:20 PM
ploglet
13
01-03-2008 06:49 AM
Johan99
Audi allroad
03-08-2006 12:14 PM
Dr.Duct_Mossburg
10
01-27-2006 08:48 PM
Dr.Duct_Mossburg
10
12-25-2005 09:24 PM
Quick Reply: Wheel fit question
