2003 AR 132k~ coolant leak
#11
Yeah, unfortunately 9hrs sounds right; that is book time....my guy did it in about 3-4 hours (paid him for 6 I think)
It's like doing a t-belt in that the front end needs to come off. Big PITA labor thang getting to it...as you know. Good luck !! Make sure they use a genuine Audi part.
#12
Betcha it's this...
Massive loss of coolant directly caused by this failure:
It's the plastic thermostat housing - a crappy plastic pipe that joins the thermostat to the lower radiator hose. See that nasty nine-inch crack? Yeah, it nearly KILLED my engine!
I have no idea why such a innovative, forward-thinking company like Audi would use such a ***-backwards part. Call your friendly dismantler and replace with the 100% compatible B5 S4 all-aluminum part(the LAST ONE your 2.7 will ever need):
Here is how it looks on your engine(circled in yellow):
Installing this part should be done with full TB service. Otherwise, I was able to get it on in about 4hrs, by sliding the timing belt away from the Passenger cam pulley by 1/2":
#13
Just a warning to those who are using VEMO t-stats on the allroad (or any other 2.7/2.8 that might have used the plastic thermostat cover).
I discovered the VEMO is about 1.5-2.0mm taller than the factory Audi/VW t-stat. This means when it's seated and you tighten the cover the top of the t-stat is putting pressure on the plastic housing. Eventually it'll crack.
My car has had a very slow leak since I bought it. Gradually it got worse. Since it leaked over the alternator I suspected the cover in some way. I found that during the one of the PO's maintenance procedures someone installed a VEMO stat causing my cover to crack and leak. Fortunately I bought an OEM one and it fit better in both the cracked plastic housing as well as fitted mint in the aluminum cover I picked up.
078 121 121 J is the alum
078 121 121 K is the plastic
078 121 113 F is the OEM t-stat (must order ring also)
Another tip - there was no way I could get the covers in and out around the t-belt without pulling the alternator and the alt mount off. Once those were out of the way it was a snap.
cheers!
cheers!
#14
Kristopher,
read your post (from 6 years ago), I have a leaky thermostat housing. What intrigued me was that your post implies I can finagle the thermostat housing out from behind the timing belt if I remove the alternator. Am I reading that right, as I would love to avoid locking the cams and all that that entails?
#16
#17
Curious if your cover was plastic and cracked?
#19
X-Tonic Tiptronic
08-17-2004 11:58 AM
AEGA4
12-05-2003 05:27 PM
LosGatosS4
16
10-10-2003 12:56 PM
