ABS wheel speed sensor..
Anyone selling a ABS sensor with part number : 4Z7927803A
Audi allroad 2,7 2001 |
ABS sensors are one of those things I would not buy used.
Originally Posted by MrKid
(Post 24820965)
Originally Posted by Kendall Larsen
(Post 24820978)
If you reach the dallas city then there is provide audi service dallas which gives complete repair solution of your audi car.
Ignore the post above, he wants to charge you to diagnose the problem.
Do you have VAG COM? If not, you should. Well worth the money it will save you in diagnostic fees. Start by removing the sensor and cleaning it. They tend to get pretty nasty over the years. Make sure the mating surface is smooth, or the sensor can be pushed away from the ring just enough to through a code. |
(Post 24821019)
Do you have VAG COM? If not, you should. Well worth the money it will save you in diagnostic fees. Start by removing the sensor and cleaning it. They tend to get pretty nasty over the years. Make sure the mating surface is smooth, or the sensor can be pushed away from the ring just enough to through a code. I have vcds and my problem started when i clicked on testing ESP something, and after that i havent been able to exit the test, so that is why i dont want to buy a new sensor, because i am not sure if it is the sensor. The old sensor did not give me any codes, as soon as i got in the test mode, it could not exit, it was then i found out that the cable was cut, changed and still same problem. |
Interesting...
You may want to contact Ross Tech. I have never had a problem with a test getting "stuck". I could always back out, despite a failure. I did it yesterday, as a matter of fact, after trying to set readiness and had a lambda failure. |
(Post 24821035)
Interesting...
You may want to contact Ross Tech. I have never had a problem with a test getting "stuck". I could always back out, despite a failure. I did it yesterday, as a matter of fact, after trying to set readiness and had a lambda failure. This is were it get stuck, it is i think because of wrong or faulty ABS sensor. |
If you get stuck in any form on Ross tech, you have a problem with what you are trying to tests. Happens to me all the time on various items, such a pin issues with a AEB style throttle body. Then I change the connector and it runs the tests
Originally Posted by transman
(Post 24821062)
