AC Issue at stop light
Hi,
I just had my AC compressor replaced and it works great on the highway except when I'm at a stop light it will blow hot air. I was told something isn't working when the car is stopped and the pressure get high. Any guesses what is wrong with it?
Thank you,
Thank you,
If you have VCDS, you can also go in and connect to the HVAC head and check the compressor shut down code. If there's anything funky going on with the compressor it will report something there.
You should find yourself a local Audi shop/guy who's very familiar with the system to help you. VCDS is invaluable to have so if you haven't purchased that yet, you should get that. (or some equivalent)
My AC fan crapped out, like you said it was easy to test with voltage from the battery, also check if you have volts from the harness connector. It either works or it doesn't. AC worked great when it was moving but in traffic or at stop lights it blew warm air.
It's a pain to replace, the bottom screw is way down and is blocked by a hard oil cooler (tx cooler?) pipe. Other than pulling the bumper off the only way to get at it is with a disco and a torx bit. And some scraped knuckles.
It's been to dang hot to mess with. Once it cools off outside I can mess with it more. Not sure if I need to replace both fans or just the one in front. Might order one soon and try to mess with it at night maybe.
Even if I need two fans, replacing one should help.
I'm going to unplug the fan and hook it up to the battery before I buy a new fan. Does it matter which wire goes on which side of the battery? I figure it'll just decide which way the fan turns.
I wired the fan to the battery so it was on and I started the engine with the ac on. It seems to blow cold and then the engine stumbles and it blows hot for 30 secs and then the engine stumbles and it blows cool again.
