Cam belt change
Old 01-09-2014, 03:00 AM
chriswilly's Avatar
Default Cam belt change
Good morning everyone.
I LOVE AUDI'S.
I currently run an A6 Allroad year 2000, 2.5 V6 diesel, Auto and I love it.
The Allroad has done 133k miles with a good service record to 125k when I acquired it.
On a time basis it needs a Timing Belt change and have noticed that the AUX belt is beginning to 'crack up'.
Went to my dealer who quoted me £1200!!!!!!
Has anyone any personal information about a cam belt change on this model, please?
I have owned 5 Audi's over the years and have changed belts on two of them, albeit five cylinder models.
I am pretty old but have spent several years in the 'trade' and have tools but no money!!
Thanks, Chris
Old 01-09-2014, 04:04 AM
bagpipingandy's Avatar
I LOVE AUDI'S.
Thanks, Chris
Hi Chris,
there is a lot to the V6 timing belt but you can DIY OK but you NEED a manual,
you also need the locking tools, crank, 2 x cam, Fuel pump, you cannot just mark it and hope for the best, the sprockets on the cams are on a taper and need loosening to set the belts properly, so you lock the actual cam and rotate teh sprocket once loosened, also once back together you need VCDS (VAG COM) to set the injector pump timing properly
it is expensive for all parts £400+ depending on what you want to change
timing belt
rollers kit
tentioners
v-belts
thermostat
i recomend a MUST is to change the thermostat while its in bits and the Tentioner bushes for the pivot for the Poly V Belt,
the thermostat can only be changed with teh belt off so to do it later is a nightmare, also the tensioner bushes are common to wear pulling the tentioner off square and pulling the v-belt off and you can then imagine the damage it can do,
regards
Andy
Old 01-09-2014, 04:59 AM
Kneale Brownson's Avatar
While in there, I also replaced the POS plastic thermostat housing with the metal one from an S4. There's a fairly complete write-up in the AW technical section, but don't skip the installation of the timing lock pin as outlined in the Bentley manual.
Old 01-09-2014, 07:54 AM
amiram's Avatar
Default work shop manual
I LOVE AUDI'S.
Thanks, Chris
Try to buy ElsaWin it is the best work shop manual for this car. And it says what special tools you need for this job
Old 01-09-2014, 09:54 AM
Forgot water pump too!! was in a rush!!
Old 01-10-2014, 04:40 AM
snagitseven's Avatar
If the timing belt service hasn't been done in the past, on a 13 year old Audi with 125K miles, it should be done as soon as possible. Since the car's age is a factor as well as miles, it's living on borrowed time. My 2002 allroad was done at 7 years old with only 43K miles due to age deterioration of the belt.
If you're not inclined to DIY, a good Audi indy shop should be able to do the complete job including belt, thermostat, tensioners and water pump for about 25% less than what was quoted by the dealer.
xaviertkhh
08-18-2018 10:34 AM
lotuseleven
12v V6 Discussion
10-07-2015 03:27 PM
Stubborn, but Happy
Audi allroad
09-12-2015 12:58 PM
SpedhedEd
09-10-2015 06:02 AM
stormchaser1967
09-02-2015 12:47 PM
Quick Reply: Cam belt change
