Allroad - Automatic Gearbox Issues
Hi to all,
I recently purchased a 2003 Audi 2.5 diesel audi allroad. Car had been driving fine and I was getting great use of it during the last period of snow. On my last trip I drove through a pile of snow that had piled up in the middle of the road. It wasn't that high but I did hear it scrap of the bottom as I went over it. I drove for about 100 metres then I had to stop for oncoming traffic (we were down to single lane at this stage). I then put it onto drive but nothing happened. I tried all options D / R / 1 - 3 but to no avail. I pushing car in off the road and got it collected the follow day.
I pulled in the VCDS and am getting the following codes;
1 Fault Found:
01375 - Valves for Engine Mounting; Stage 1
38-10 - Output won't Switch or Short to Plus - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 H
Component: AG5 01V 2.5lTDI RdW 2121
Coding: 00001
Shop #: WSC 00000
VCID: 4B95011A7987221E34-515A
2 Faults Found:
17090 - Transmission Range Sensor (F125)
P0706 - 35-10 - Implausible Signal - Intermittent
18161 - Tiptronic Switch (F189)
P1753 - 35-00 - Implausible Signal
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06457
Shop #: WSC 02325
VCID: 4A9B041E76FD3B160F-515A
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 H
Component: Airbag 8.4EP 2000
Coding: 0001106
Shop #: WSC 02325 785 00200
VCID: 54A71A66F4B97DE665-515A
2 Faults Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
010 - Open or Short to Plus - MIL ON
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 04460
Shop #: WSC 00230
VCID: 2D516F82E7530C2E0A-515A
WAUZZZ4B43N080162 AUZ7Z0B2296490
6 Faults Found:
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
01176 - Key
07-10 - Signal too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01315 - Transmission Control Module
00562 - Sensor for Oil Level/Temperature (G266)
29-10 - Short to Ground - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 00430
VCID: 489F3E1668F1C90619-513C
1 Fault Found:
01400 - Suspension Level Control
53-10 - Supply Voltage Too Low - Intermittent
Is it possible that may have disconnected something underneath? I have access to a ramp over the weekend so I will be able to have a good look at it. There's a brand new battery in it so it's not that.
Any advice appreciated.
Bert
1 Fault Found:
Readiness: N/A
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
Coding: 06457
Shop #: WSC 02325
1 Fault Found:
Coding: 0001106
2 Faults Found:
Coding: 04460
Shop #: WSC 00230
6 Faults Found:
01176 - Key
Coding: 25500
Shop #: WSC 00430
1 Fault Found:
Bert
remove the bottom shield \ noise isolator at the bottom of the car and check for any damage to the electrical power plug that enter to the transmission (in the bottom part)
Update: Eventually managed to change the 'Transmission Range Sensor' (bit if a nightmare of a job) and that seem to sort out all the lights flashing up in the cluster at the same time. Unfortunately that's all it did as the car still does not drive. Initially my friend ran his Ross software (I think that's what its called) and the above codes were coming up. After installling the TRS we then cleared the codes. Now when we run software again nothing comes up. It there any way that the software can see if the gearbox is working, and if so how do you test it? At this stage I'm stumped.
Thanks for previous advice.
Bert
Bert
lilya
Q5/SQ5 MKI (8R) Discussion
03-20-2015 12:56 PM
TTinCT
29
01-06-2005 06:52 PM
S4Frank
12
06-01-2003 03:53 AM
Lurk'n
11
12-11-2002 06:24 PM
