Another allroad suspension issue....
So I'm a bit depressed right now lol 4 new bags, Compressor freshly rebuilds with Andy kit, 40 Amp fuse is fine, the relay is good. but the compressor won't start. I jumped the compressor with Wire and it is working.
VCDS is throwing me some weird code.
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
VCID: 4797400A65E8B17CA6-5072
8 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
31-00 - Open or Short to Ground
00805 - Suspension Strut Valve; Left Front (N148)
00806 - Suspension Strut Valve; Front Right (N149)
01400 - Suspension Level Control
53-10 - Supply Voltage Too Low - Intermittent
00807 - Suspension Strut Valve; Rear Left (N150)
00808 - Suspension Strut Valve; Rear Right (N151)
01773 - Level Control Accumulator Valve (N311)
31-10 - Open or Short to Ground - Intermittent
01397 - Venting Solenoid for Level Control (N111)
I tought i had wire issue so i replaced the 10 pin connector and soldered all the wire with heat shrink and made sure all color are matched properly. but im still getting the same problem
Also which module is sending signal to the compressor relay cause i only have 12v on one of the wire( top one ).
Coding: 25500
Shop #: WSC 09999
8 Faults Found:
Coding: 25500
Shop #: WSC 09999
8 Faults Found:
Coding: 25500
Shop #: WSC 09999
8 Faults Found:
It looks like a problem connecting to a valve block. First delete the fault codes and see What will come back again because disconnecting the electrical plug to the valve block will produces these codes. Check the socket and electrical plug to the valve block
